    File Access Problems
    2 Posts 0 Posters 263 Views
      On 24/03/2006 at 15:51, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      Hi there guy's
      Im quite new to playing with c.o.f.f.e.e. - hopefully you can help
      1...
      im trying to read from a file.
      nothing complex.
      Ive got a c.o.f.f.e.e. node in an xpresso tag...
      in it it includes the lines of...
      var srcfile = new(BaseFile);
      srcfile->Open(filename, GE_READ);
      var myreal = srcfile->ReadReal();
      filename contains the path\filename to a file. (hardcoded at the moment 🙂
      Does absolutely bugger all. Doesnt even seem to try to open the file.
      Now would I be right in saying that you cant use file operations from c.o.f.f.e.e. nodes in xpresso tags? Im sure i remember reading that somewhere - cant see it in the sdk I downloaded though!
      If that is the case, can I just stick it in a propper c.o.f.f.e.e. tag instead and it should work? (I have no idea how to create simple input/output ports that i can attatch to other stuff on a c.o.f.f.e.e. tag, like you can with an xpresso tag - so dont really know how to go down this route yet)
      2...
      Is there a coffee instruction to return the path of the current document, i can only seem to find an instruction to return the current c4d install path.
      If all that makes sense!
      Many thanks in advance
      martin!
        On 31/03/2006 at 11:07, xxxxxxxx wrote:
        1. It seems to work here. Perhaps the filename is wrong? I don't know how you're creating the filename, but an easy way is to use a filename port as input for the C.O.F.F.E.E. node. (I have exactly the same code as you!)
        2. BaseDocument::GetFilename()
