    BuildNgonFromPolys() failing...
    42 Posts 0 Posters 35.8k Views
      On 15/03/2006 at 13:44, xxxxxxxx wrote:
      The SDK doc is actually incorrect for the outer, unlike the BuildNgon function the BuildNgonFromPolys can not support holes so the 'outer' is simply an array of the ngon outer edges.
      If you need to use holes then BuildNgon must be used. Normally this function is used because you already know the ngon outline and have triangulated the ngon yourself so wish to pass the ngons outer edges and also the polygons for the triangulation (e.g. during file import).
      If you don't already know the ngon outline then you will need to find this based on whatever you do know, is that just a list of connected polygons? The Neighbor class might help if you just know the vertices or polygons.
        On 16/03/2006 at 02:13, xxxxxxxx wrote:
        Ahh, thanks again David... but related to the above:
        1. I don't need to create holes.
        2. I know exactly which polygon indices will make up the Ngon and those polys are already created.
        3. I know exactly which vertex (point) indices are used to make up the outer edge of the polygon.
        ...the issue that's still not clear to me is:
        >> ...so the 'outer' is simply an array of the ngon outer edges.
        ...sorry if I'm being dense, but I guess I still hadn't found a way to know what 'index' any particular edge a->b of a particular polygon IS.  It sounds like every edge found within the PolygonObject has a unique/numbered index and that that index value is what the array is made up from, but I don't know how to GET that index value for the edges in question.
        If it was simply an array of the POINT indices that make up the Ngon, that would be simple - I have those readily available.  But to get the edge indices, the round-about way I see so far would be to:
        - initialize a Neighbor object with the PolygonObject info
        - for each triangle that will make up the Ngon, call polyinfo = neighbor->GetPolyInfo()
        - In my particular case, the first two (outer) edges of each triangle are the ones I need an index for, so I get those two PolygonObject-relative 'edge index' values from polyinfo->edge[0] and polyinfo->edge[1] (???)
        ...is that right? Is that the uniquely numbered edge indices I need for the array passed to BuildNgonFromPolys() ? (from some initial tests, that doesn't seem to work).
        - Keith
          On 16/03/2006 at 02:17, xxxxxxxx wrote:
          ...also, if I don't call ResizeObject(), then my call to GetNgonBase() fails (at least if the object has ot yet been attached to the document... I can go ahead and add it to the document first, but I'm still fuzzy on building the edge-index array).
            ..sorry, I had typed that question in before I tried the code.  In my particular case (loading .obj files from disk and triangulating the Ngons and reversing the winding order to show up in C4D correctly...) what I actually needed was two edges from the last triangle (0,2), two edges from the first triangle (0,1) and just the middle edge (0) from the other triangles.
            But it's still not working.  And in fact, I'm crashing the app with what I'm doing....sigh.
              On 16/03/2006 at 03:12, xxxxxxxx wrote:
              The NgonBase is created only if Ngons are needed (to save memory), a way to force this to be created when you have no ngons but will be needing to add them is to call GetNgon. Once that has been called then GetNgonBase should return a valid pointer provided everything went ok. (see Modeling Library in the SDK docs)
              Edges are defined as the polygon index * 4 + (0 to 3) for each edge around the quad (see PolyInfo in the SDK docs). Building the ngons from what you have is just a case of passing the BuildNgonFromPolys the array of polygons and then an array of edges that form the outline of the ngon.
              The outline edges are easily found from the vertices using the Neighbor class. Take the first vertex in your array and use GetPointPolys to find all polygons associated with that vertex, then look at each one and find the edge that matches to the next vertex in your array, that will give you the edge. Repeat this around your vertices and you'll have an array of the corresponding edges. The outline array must be ordered so each edge is the next one around the ngon.
              You could also use the modeling library, delete all polygons that are part of each ngon and use CreateNgon with the vertices you have to rebuild the ngons. The Modeling library will then triangulate them itself on Commit.
                On 16/03/2006 at 03:20, xxxxxxxx wrote:
                Sorry for the spam-fest :)... I'm just at a loss for what's going on.  Has anyone ever used BuildNgonFromPolys() successfully?   I'd realy like to use that, because as far as I can tell, other methods of creating Ngons will end up re-ordering my vertices and/or polygons (which would break morph targets = a bad thing ).
                Would it be possible to get any sort of (known to be working) example code that uses BuildNgonFromPolys()?   This is just taking far too much of my time (and yours, I presume)  trying to devine meaning from the given documentation in present form.
                If it was just for me, I'd just blow off this feature all together (I don't need Ngons for my purposes - or this frustration), but I made a promise (to Maxon) to update Riptide to work with R9 and Ngons, so.... here we are.
                Your help is and has been much appreciated - thanks,
                - Keith
                  On 16/03/2006 at 03:22, xxxxxxxx wrote:
                  Good Morning David.. we cross-posted.. let me read through your latest reply and see if anything clicks.
                  - Keith
                    On 16/03/2006 at 04:02, xxxxxxxx wrote:
                    I did a search and could find no use of BuildNgonFromPolys in any CINEMA core source, it looks like an unused function. Reason is probably that is easier to use BuildNgon since you don't need to pass a list of polygons, just the outer edges or internal edges (in your case outer is easier to find). Both functions are actually just helpers, you could also just use the Create function and build the ngon edges yourself; however this means adding in the correct marked bits but in your case this is much easier since you have no holes.
                    Generally it is much easier to use the modeling library and leave it to deal with the internal ngon data, however, in some case (like import when you have the polygons already) or generators (where you need speed) you have to use the direct ngon library itself which is more complicated.
                    First thing to get right is to build your edge outline as I mentioned, once you have this then you have options on how to build/create an ngon. If you only need to keep your vertex order then you can use the CreateNgon of the modeling library, this will not change your vertex order. The modeling library always tries to keep the order of anything it can, even on deleting vertices it will only remap those that it needs to in order to fit the new point count. If you need to keep your polygons and vertices then you'll have to build the ngon manually from the edges.
                    Here is a small cut of source that uses BuildNgon for import:
                        LONG ngon_start=0,ngon_end=0,eind=0,lastface=NOTOK;
                        LONG *edges = (LONG* )GeAlloc(sizeof(LONG)*4*polyanz);
                        PolygonObject *pObj = obj;
                        pObj->GetNgon(); // necessary to build variables
                        NgonBase *pNgons=pObj->GetNgonBase();
                        if (pNgons && edges)
                          pObj->Message(MSG_UPDATE);
                          LONG i=0;
                          for (t=0; t<=fmax;)
                            if (t<fmax)
                              f=(WFFace* )group->face.Get(t++); if (!f) { SetError(); break; }
                              anz = f->fnum;
                            else
                              anz = 3;
                            if (anz==3 || anz==4)
                              if (lastface==NOTOK) lastface = f->realface;
                              if (t==fmax || f->realface!=lastface)
                                if (ngon_end-ngon_start>1)
                                  if (pNgons->BuildNgon(edges,NULL,eind,0,pObj->GetPolygon(),pObj->GetPoint())==NOTINDEX)
                                    // error
                                if (t==fmax) break;
                                ngon_start=ngon_end=i;
                                lastface=f->realface;
                                eind=0;
                              if (f->bits&1)
                                edges[eind++] = 4*i+1;
                              if (f->bits&2)
                                edges[eind++] = 4*i+0;
                              if (f->bits&4)
                                edges[eind++] = 4*i+3;
                              ngon_end=i;
                              i++;
                            t += anz;
                          pNgons->InitMap();
                          pNgons->SetFlags(NGON_FLAG_NOVALIDATION);
                        GeFree(edges);
                    Note the NGON_FLAG_NOVALIDATION is set prior to a MSG_UPDATE to inform the ngon handler that it does not need to check any of the structural changes to the object since the ngons are known to be valid. When ngons are found and MSG_UPDATE is called without this flag set then the ngon handler must check all polygon changes have no invalidated the ngon structures, if they have the invalid ngons are removed. This overhead is costly so it should be avoided when possible, e.g. on import when you know the data is correct.
                      On 16/03/2006 at 04:26, xxxxxxxx wrote:
                      Hmm, Since BuildNgonFromPolys() is not being used anywhere, I wonder if it might be broken (or further mis-understood/documented)... anyway, I should hit the sack, so I'll take a look at the modelling library stuff after some sleep.
                      Thanks again!
                      ZZzzzzzz...
                      - Keith
                        On 16/03/2006 at 10:02, xxxxxxxx wrote:
                        Ok, got a few hours sleep and... Success! (yay)
                        The final two changes I needed were:
                        1. I had been using:
                        *pEdge++ = (pNgons->polys[ndx] * 4)+2; // edge #2
                        ...in a spot where I needed to be using:
                        *pEdge++ = (pNgons->polys[ndx] * 4)+3; // edge #3
                        (this is the first time I've messed with edges, so I missed that detail of how triangles are treated vs quads)
                        2. I switched from BuildNgonFromPolys() to BuildNgon().
                        ...As far as I can determine, I had been passing in the correct polygons in the correct order, but BuildNgonFromPolys() was just not working (even after fix #1 above).
                        Thanks for bearing with me on this and all the help!
                        - Keith
                          On 16/03/2006 at 11:56, xxxxxxxx wrote:
                          Looks like there's one missing detail now...
                          If I load a .obj file with Ngons using C4D's built-in import, and then set the Structure Browser mode to 'Ngons', I see the list of Ngons/polys, but using my plugin, that list is empty... is there something I need to call to get that list to refresh?
                          - Keith
                            On 16/03/2006 at 12:20, xxxxxxxx wrote:
                            The only reason I can think of is if no ngons are in the object, even though you add them it is possible for the ngon handler to throw them out again if it finds anything invalid (to prevent crashing). After you have finished importing, print out to the console the imported ngon count you should have imported and then what you find in the objects. Does this match? I'll check the BuildNgonFromPolys function to make sure its working, as its unused in CINEMA itself any bugs may have been missed but I should have checked all the functions prior to release (its been a while, can't remember exactly).
                              On 20/03/2006 at 11:26, xxxxxxxx wrote:
                              Hey David,
                              I checked and the Ngons are being created and the Ngon count seems to be correct.  In fact, I finished implementing the export side of things and all the calls used for that are retrieving the data correctly as well - but if I set the display Mode to 'N-Gons' in the Structure Browser, it's blank (no polys, no ngons, no nothing is listed).
                              This is the code that I finally got working:
                                  //======== S N I P - bunch-o-code above here to set up the object
                                   if( m_opt_mpNgons && m_numNgons ) // see if we need to set up Ngons...
                                    op->GetNgon();     // force NgonBase to be created
                                    pNgonBase = op->GetNgonBase();
                                    if( pNgonBase )
                                     op->Message(MSG_UPDATE);
                                     NgonLoader *pNgons = &m_pNgons[0];     // <-- NgonLoader is my own structure
                                     for(i=0; i<m_numNgons; i++)
                                      LONG ndx;
                                      LONG *pEdge = &m_pEdgeList[0];     // <-- array big enough to hold max-ngon-edges
                                      if( m_opt_mpRevFaces )
                                       for(ndx=0; ndx<pNgons->polycnt; ndx++)  // default action is to reverse faces, so this logic is backwards...
                                        if( ndx == 0 )       // if this is the first poly, add edge #0
                                         *pEdge++ = (pNgons->polys[ndx] * 4)+0;
                                        *pEdge++ = (pNgons->polys[ndx] * 4)+1; // add edge #1
                                        if( ndx == pNgons->polycnt-1 )   // if this is the last poly, add edge #3
                                      else
                                       for(ndx=pNgons->polycnt-1; ndx>=0; ndx--) // need to reverse order for proper winding
                                        if( ndx == pNgons->polycnt-1 )   // if this is the first poly, add edge #3
                                        *pEdge++ = (pNgons->polys[ndx] * 4)+0; // add edge #0
                                        if( ndx == 0 )       // if this is the last poly, add edge #1
                                      pNgonBase->BuildNgon(NULL, m_pEdgeList, 0, pNgons->polycnt+2, vadr, padr);
                                      pNgons++;
                                     pNgonBase->InitMap();
                                     pNgonBase->SetFlags(NGON_FLAG_NOVALIDATION);
                                   doc->InsertObject(op,NULL,NULL);
                                   op->MakeTag(Tphong);
                                   doc->SetActiveObject(op);
                              ...in the above code, the 'NgonLoader ' is my own structure, that keeps track of the triangles (no quads, in this case) that make up the Ngons.  Also, by default, I reverse the winding order of polygons on import, to fit C4D's system (there's an option that lets you 'reverse faces', which in this case actually loads them as they are found in the file).  Anyway, the above code checks for each condition and sets up the Ngon edges appropriately for each case.
                              So, as I mentioned, the code 'appears' to be working correctly - it creates Ngons, which are visible/selectable/etc. in the editor window, if I enable the option to view Ngons, I can see the original triangles that make up the Ngons and op->GetNgonCount(), op->GetPolygonTranslationMap(), op->GetNGonTranslationMap(), op->GetNgon() and op->GetNgonEdgesCompact() all seem to be working correctly.  The only thing that seems to not be working is the Structure Manager display, as described above.
                              Any thoughts?
                              - Keith
                                On 20/03/2006 at 11:46, xxxxxxxx wrote:
                                BTW, I just thought I'd comment on something for future reference...
                                "The Ngon System sucks" :).
                                ...I feel better now :).  Seriously though, it could be that I missed something, but I noticed that it's just really really tedius trying to figure out a list of points that make up any particular Ngon.  I mean.. you can:
                                ngonCnt = op->GetNgonCount(); // <-- usefull information
                                Pgons = op->GetNgon(); // <-- more useful data
                                Pgons[i].GetPointCount(); // <-- cool, we know how many points but...
                                Pgons[i].GimmeDaDamnPoints(&mybuffer); // <-- ...where's this helper function???
                                ...instead, you have to jump through a bunch of hoops looping through edges (and making sure to get the rght order of edges, at that), then extract the points used by those edges.
                                As I mentioned, it's possible that I just missed something, or went about it entirely the wrong way, but having not written the code to start with (ie. from an outside perspective), it's just really non-obvious.  My exporting code seems to be functioning fine now, I'm just not completely comfortable that it will continue to work without changes in future versions of C4D.
                                Just some food for thought...
                                - Keith
                                  On 21/03/2006 at 00:42, xxxxxxxx wrote:
                                  Sorry no idea why the structure manager isn't working. The best bet would be to send an example file with your compiled plugin to the sdk support mail and I'll take a look for you.
                                  As for the ngon library, as I mentioned before the intention is to use the modeling library and not directly using the ngons since this is more work and the library essentially is just giving you raw access with a few helpers. Its not really advisable to use the ngons directly since this is a delicate area and can easily cause crash problems if the data is wrongly setup. The modeling library is easier and safer.
                                    On 21/03/2006 at 05:22, xxxxxxxx wrote:
                                    Ok, I'll try to send something for you to look at once I get to a breaking point - thanks.
                                    As for the ngon library, I'm not opposed to using that, or married to an particular set of calls - I'm just trying to figure out 'how' to do what I need to do.  For Riptide, I need to do 2 things, related to ngons...
                                    1. For Import: read an .obj file, which might include ngons and if so, set those up in the resulting C4D PolygonObject, without changing the vertex ordering.
                                    2. For Export: parse a C4D PolygonObject to determine if it has any ngons and if so, determine which polygons make up the ngons (so I don't write those out as tris/quads) and then determine the actual ngon point indices that make up the ngons, so I can build proper .obj file format facet records for the ngons.
                                    ...my import code is shown above and is just using pNgonBase->BuildNgon() (which I guess qualifies as "ngon library" ?).  The export code is a bit more involved, because I was trying to find some way of getting the information I needed.   Here's the basic code I'm using for exporting:
                                        // here's a few of my internal support structures...
                                        typedef struct _objFacet // facet (or 'face') structure
                                         DWORD fctFlags;
                                         DWORD iMatNdx;   // material ID/index
                                         DWORD iGroupNdx;   // group ID/index
                                         DWORD iRegionNdx;   // UVMapper region index
                                         DWORD iPolyNdx;   // vertex indices
                                         DWORD iNgonNdx;   // which Ngon this face is part of (if any)
                                         DWORD v[4];
                                         DWORD t[4];
                                         DWORD n[4];
                                         DWORD vCount;    // num vertices in this face
                                        } objFacet;
                                    typedef struct _ngonsavedata
                                     Bool bWritten;
                                     DWORD *v;
                                     DWORD *t;
                                     DWORD *n;
                                     DWORD vCount;    // num vertices in this ngon
                                    } NgonData;
                                    void ObjSaver::GetNgonsData(PolygonObject *op)
                                     NgonData *pNgonData;
                                     Pgon *pPgon;
                                     LONG ngoncnt, *polymap, **ngons;
                                     LONG i, j, numpolys, numpoints, loopBreak, ptCnt, firstPt, nextPt;
                                     UCHAR *edges;
                                     m_numNgons = op-> **GetNgonCount** ();
                                     if( !m_numNgons )
                                      return;
                                     m_pNgonsData = (NgonData * )GeAlloc(m_numNgons * sizeof(NgonData));
                                     if( !m_pNgonsData )
                                      m_numNgons = 0;
                                      return;
                                     if( !op-> **GetPolygonTranslationMap** (ngoncnt, polymap) )
                                      GeFree(m_pNgonsData);
                                      m_pNgonsData = NULL;
                                      m_numNgons = 0;
                                      return;
                                     if( !op-> **GetNGonTranslationMap** (ngoncnt, polymap, ngons) )
                                      GeFree(polymap);
                                      m_numNgons = 0;
                                      return;
                                     pPgon = op-> **GetNgon** ();
                                     op-> **GetNgonEdgesCompact** ( **edges** );
                                     pNgonData = &m_pNgonsData[0];
                                     for(i=0; i<(LONG)m_numNgons; i++)
                                      numpolys = ngons[i][0];
                                      numpoints = pPgon[i]. **GetPointCount** ();
                                      pNgonData->v = (DWORD * )GeAlloc(numpoints * sizeof(DWORD));
                                      pNgonData->t = (DWORD * )GeAlloc(numpoints * sizeof(DWORD));
                                      pNgonData->n = (DWORD * )GeAlloc(numpoints * sizeof(DWORD));
                                      pNgonData->bWritten = false;
                                      ptCnt = 0;
                                      j = 1;       // the index list starts at ngons[i][1]
                                      loopBreak = 0;
                                      firstPt = NOTOK;
                                      nextPt = NOTOK;
                                      // The hoop-jumping below is tedius... I wish I could replace it all with a single helper
                                      // function call -> pPgon[i].GetPoints()
                                      while(loopBreak < numpoints) // allow for complete poly scan per point
                                       LONG polyndx;
                                       objFacet *pFacet;
                                       polyndx = ngons[i][j];    // get the polygon index
                                       pFacet = &m_pFaces[polyndx];  // get ptr to this facet
                                       pFacet->fctFlags |= FCTF_ISNGON; // flag it as an Ngon
                                       pFacet->iNgonNdx = i;    // and store the Ngon index for later
                                       // The basic strategy is to look at each 'active' edge, extracting the points that make
                                       // up the outer edge of the Ngon. Since the order of those edges is not necessarily
                                       // correct, keep track of 'which' edge we're looking for next (the next correct edge will
                                       // have it's first point == the second point of the previous edge).
                                       // Since the edge list is out of order, we might have to pass up some edges and scan
                                       // through the list from the top again for any particular point we're looking for, so
                                       // the loop-control is set up to allow for one list-scan per point.
                                       // In hindsight, I guess I could have just stored all the edges and implemented a 'sort'
                                       // on them (based on the critera above), but that didn't occur to me when I wrote this code :).
                                       // Also note that some polygons that make up the Ngon may not have any edges that make
                                       // up the (outer) edge of the Ngon.
                                       if( !( **edges** [polyndx] & (1 << 0)) ) // edge 0
                                        if( firstPt == NOTOK )
                                         firstPt = m_pPolys[polyndx].a;
                                         pNgonData->v[ptCnt] = m_pPolys[polyndx].a;
                                         if( m_pUVndx )  pNgonData->t[ptCnt] = m_pUVndx[polyndx].a;
                                         if( m_pNormNdx ) pNgonData->n[ptCnt] = m_pNormNdx[polyndx].a;
                                         ptCnt++;
                                         nextPt = m_pPolys[polyndx].b;
                                        else if( m_pPolys[polyndx].a == nextPt )
                                         ptCnt++;
                                        if( ptCnt == numpoints )
                                         break;
                                       if( !( **edges** [polyndx] & (1 << 1)) ) // edge 1
                                         firstPt = m_pPolys[polyndx].b;
                                         pNgonData->v[ptCnt] = m_pPolys[polyndx].b;
                                         if( m_pUVndx )  pNgonData->t[ptCnt] = m_pUVndx[polyndx].b;
                                         if( m_pNormNdx ) pNgonData->n[ptCnt] = m_pNormNdx[polyndx].b;
                                         ptCnt++;
                                         nextPt = m_pPolys[polyndx].c;
                                        else if( m_pPolys[polyndx].b == nextPt )
                                         ptCnt++;
                                         break;
                                       if( pFacet->vCount == 4 ) // only process edge 2 if this is a quad
                                        if( !( **edges** [polyndx] & (1 << 2)) ) // edge 2
                                          firstPt = m_pPolys[polyndx].c;
                                          pNgonData->v[ptCnt] = m_pPolys[polyndx].c;
                                          if( m_pUVndx )  pNgonData->t[ptCnt] = m_pUVndx[polyndx].c;
                                          if( m_pNormNdx ) pNgonData->n[ptCnt] = m_pNormNdx[polyndx].c;
                                          ptCnt++;
                                          nextPt = m_pPolys[polyndx].d;
                                         else if( m_pPolys[polyndx].c == nextPt )
                                          ptCnt++;
                                          break;
                                       if( !( **edges** [polyndx] & (1 << 3)) ) // edge 3
                                         firstPt = m_pPolys[polyndx].d;
                                         pNgonData->v[ptCnt] = m_pPolys[polyndx].d;
                                         if( m_pUVndx )  pNgonData->t[ptCnt] = m_pUVndx[polyndx].d;
                                         if( m_pNormNdx ) pNgonData->n[ptCnt] = m_pNormNdx[polyndx].d;
                                         ptCnt++;
                                         nextPt = m_pPolys[polyndx].a;
                                        else if( m_pPolys[polyndx].d == nextPt )
                                         ptCnt++;
                                         break;
                                       // funky loop control...
                                       if( j == numpolys )
                                        j = 1;
                                        loopBreak++;
                                       else
                                        j++;
                                      pNgonData->vCount = ptCnt;
                                      pNgonData++;
                                     GeFree(polymap);
                                     GeFree(ngons);
                                    ...as I mentioned, this code seems to be working fine, but I'm just not crazy about the method of going about it.  I could have replacd that entire lower loop if there was a helper Pgon->GetPoints(&my_buffer) call available.
                                    Anyway, I've highlighted the relevent calls and structures being used above and I'm guessing that my use of those is relatively benign and should continue to work, as long as the documented functionality of those calls don't change in future versions.
                                    - Keith
                                      On 21/03/2006 at 14:14, xxxxxxxx wrote:
                                      David, could you (or anyone who knows) give me the SDK Support e-mail address? I couldn't find it listed anywhere, but apparently it's not: [email protected]
                                      - Keith
                                      *** Ok, I did a forum search and it looks like it might be [email protected] so I sent it there.  If you don't get my e-mail let me know.
                                        On 21/03/2006 at 14:33, xxxxxxxx wrote:
                                        Got it, thanks (yes its sdk_support).
                                        I tested the import on 9.5 and it works fine, ngons are fine and the structure manager shows them correctly. What version of CINEMA are you using? Your original post says 9.1, is that correct? I don't have 9.1 on my laptop at the moment to check so if you are using 9.1 I'll check it on my desktop tomorrow.
                                          On 21/03/2006 at 18:42, xxxxxxxx wrote:
                                          Cool... yes, I am using 9.1 and seeing the same thing on both Mac and PC R9.1 on both.
                                            On 22/03/2006 at 01:29, xxxxxxxx wrote:
                                            Strange. Tested 9.1 this morning with no problems either. What happens if you run the retriangulate ngons function or the remove ngons function, does the structure manager then work?
