    Changing the number of points of a spline
    5 Posts 0 Posters 523 Views
      On 09/03/2006 at 05:45, xxxxxxxx wrote:
      Cinema 4D Version:   9.x
      Platform:      Mac OSX  ;
      I already have a spline object in my document. Now, I would like to be able to add it or subtract it points (no matter their positions, that is already solved). So, for example, the spline has 5 control points but I would like to be able to change that at will, making it have, lets say 3 or 10 points, using COFFEE, of course. Possible? If yes, how?
      Thank you in advance for any help.
      Rui Batista
        On 09/03/2006 at 06:06, xxxxxxxx wrote:
        You can try MCOMMAND_SPLINE_ROUND with a SendModelingCommand()
        -Sneaker
          On 09/03/2006 at 08:14, xxxxxxxx wrote:
          Thank you, Sneaker. It seems to work when I do it manually. But, when I try to code it in COFFEE, it can't pass the second line:
          bc=new(BaseContainer);
          bc->SetData(MDATA_SPLINE_ROUNDPOINTS,n_points);
          bc->SetData(MDATA_SPLINE_ROUNDTYPE,1);
          It tells me that "variable of function expected" at the place I have the n_points variable typed. It doesn't even work when I try to set it to a constant, like 10 or 20.
          What could be wrong with such a simple code?
          Rui Batista
            On 09/03/2006 at 14:05, xxxxxxxx wrote:
            There seems to be some missing constants.
            That code worked here
            bc->SetData(2015,99);
            bc->SetData(2016,0);
            SendModelingCommand(450000039,doc,op,bc,MODIFY_POINTSELECTION);
            I found the values in coffeesymbols.h (ID_MODELING_SPLINE_ROUND_TOOL=450000039,)
            and in toolsplineround.h
            Don't ask me how I found that, but I'm quit good in guessing without understanding too much about that all ;o).
            Edit:
            Oh, yes and the minimum points seem to be 3.
            hey, I'm glad I could help. You don't know how much I learned already from your tutorials and files.
            all the best,
            -Sneaker
              On 10/03/2006 at 18:41, xxxxxxxx wrote:
              Thank you VERY MUCH, Sneaker.
              It worked fine!! 🙂
              Rui Batista
