    Need a coffee script to build a spline
    Scheduled Pinned Locked Moved General Discussion
    4 Posts 0 Posters 849 Views
      On 09/03/2006 at 02:36, xxxxxxxx wrote:
      Dear engaged cinema friends, I have started to work with some simple coffee scripts last weekend. I am looking now for a code line for "creating a spline", want to make some experience with (helix, spline curves manipulation and so on) it and would like to adapt a splinetool from another program to cinema, the tool will be for free, if I have adapted it to cinema 🙂 I haven't found any advices in the sdk 9.5, or overread it. Perhaps somebody can help me? best regards from raining and snowing germany, frankolino :-))
        On 10/03/2006 at 04:23, xxxxxxxx wrote:
        Hi dear Cinema User, I have found such things yesterday and perhaps somebody can say, if this code lines are useful for creating a splinecurve with coffee ! 🙂 have a good weekend, bye, frankolino 🙂
        main(doc,op)_<_o:_<_o:p_>_o:p>
        _rve=op;
        var bc;
        if (instanceof(curve,SplinePrimitiveObject))_<_o:_<_o:p_>_curve->GetSplineObject();
        _nstanceof(op,SplineObject)) return;
        _o-fareast-font-family: 'MS Mincho'">
        curve->InitLength(1);
        var long=curve->GetLength();   //länge der spline_si-language: FR; mso-fareast-font-family: 'MS Mincho'">s
        var inter=lenght/(nb_objets);   //berechnet die Intervalle der splines_e="mso-fareast-font-family: 'MS Mincho'"> (splines geschlossen)
        bc=cur_RU style="mso-fareast-font-family: 'MS Mincho'">ve->GetContainer();
        var close_="mso-fareast-font-family: 'MS Mincho'">=bc->GetData(SPLINEOBJECT_CLOSED);
        _"mso-fareast-font-family: 'MS Mincho'">if (close==FALSE) inter=length/(nb_objets-1);<_<_o:_<_o:p_>_/P>
        var object=op->GetDown();  // er_<_o:_<_o:p_>_...
        if (!object) return;
        var source_object=object->GetName();<_<_o:_<_o:p_>_class=MsoPlainText>var rot_s=objet-&g;_<_o:_<_o:p_>_()->GetHPB();
        and so on...
          On 10/03/2006 at 14:50, xxxxxxxx wrote:
          For Xpresso, COFFEE, C++ development, you would probably get a quicker response if you ask in the "SDK Help" forum. 🙂
          Also, doing a search in that forum (with All to go past the current month) may provide the answer without even asking.
            On 13/03/2006 at 04:44, xxxxxxxx wrote:
            Thank you Robert! I have done it ;-), best regards, Frankolino 🙂
