    MIP mapping?
    7 Posts 0 Posters 870 Views
      On 07/03/2006 at 05:32, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      I am using GetSurfaceData to extract the surface color, but it doesn´t seem to calculate MIP filtering (although the manual does state that only TraceGeometry doesn´t calculate MIP mapping).
      What is required to let GetSurfaceData calculate MIP filtering?
      Thanks iA
      Katachi
        On 09/03/2006 at 15:36, xxxxxxxx wrote:
        I assume you passed additional vectors for MIP-mapping in Ray::pp? If so, and no MIP-mapping was calculated, it could be that GetSurfaceData() does not calculate MIP-mapping.
        I can't find the reference to TraceGeometry()/MIP in the manual. Where did you find it? (I should correct it if it's wrong.)
          On 10/03/2006 at 06:44, xxxxxxxx wrote:
          Hi Mikael,
          yes, I have passed them. The reference to TG/MIP in the manual is in the description of the routine VolumeData::GetRay().
          It says that for TraceGeometry those vectors don´t need to be filled in as it´s the only routine NOT calculating MIP.
          Here is the according text:
          > Quote: void GetRay(Real x, Real y, Ray* ray)
          > Generate the view ray for a position.
          > This function does not set pp[0..2], vv[0..2], transport and ior. Those have to be filled in if used subsequently by TraceColor(), TraceColorDirect() or GetSurfaceData(). It's not necessary for TraceGeometry() though (as there are no MIP mapping calculations).
          Seems plausible. Hope it´s my fault. 🙂
          Thanks in advance for letting me know!
          Best
          Katachi
            On 16/03/2006 at 07:14, xxxxxxxx wrote:
            So, any info on that issue?
            thx
            Katachi
              On 25/03/2006 at 05:06, xxxxxxxx wrote:
              Hmm, what has to be done to get a final word concerning this issue? I am stuck on my code and would eagerly like to know if it´s my fault or the application´s fault.
              Katachi
                On 31/03/2006 at 10:56, xxxxxxxx wrote:
                Sorry for the delay. I'm afraid I can't confirm this. I used the following code:
                     Ray r;
                     r.ior = 1.0;
                     r.p = LVector(0,0,0);
                     r.pp[0] = Vector(0,0,0);
                     r.pp[1] = Vector(0,0,0);
                     r.pp[2] = Vector(0,0,0);
                     r.pp[3] = Vector(0,0,0);
                     r.v = LVector(0,0,1);
                     r.vv[0] = Vector(0.5,0,1);
                     r.vv[1] = Vector(-0.1,0,1);
                     r.vv[2] = Vector(0,0.1,1);
                     r.vv[3] = Vector(0,-0.1,1);
                     r.transport = 0.0;
                     SurfaceIntersection si;
                     vd->TraceGeometry(&r, 1000000.0, NOTOK, &si);
                     SurfaceData cd;
                     vd->GetSurfaceData(&cd, 0, 0, 0, 0, &r, si);
                     GePrint(RealToString(cd.col.x));
                When I change 0.5 to 0.1 I get a different reading, so MIP mapping does seem to be enabled. (The code is just looking at a texture plane with MIP enabled.)
                  On 13/04/2006 at 06:39, xxxxxxxx wrote:
                  thanks for the check. Hmm, I must recheck my code then and see if I am doing anyhting wrong there (although there´s not much to do wrong).
                  Why did you set transport to 0.0 btw? I never understood for what calculations transport is used for. Can you enlighten me on this one? I know it´s the ray intensity but what is this intensity used for?
                  Thanks for your efforts
