    DescriptionCheckUpdate.descid = crash!
    2 Posts 0 Posters 269 Views
      On 04/03/2006 at 22:18, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      No matter what I do, there seems no sane way to reference the DescLevel of the DescID in a DescriptionCheckUpdate structure (no examples either). Since it is a pointer, the [] operator will not compile on dcu->descid[0].id. So I figure it needs to be dereferenced. But all my varied attempts so far equal compiler error or a Cinema 4D crash - specific to the marked lines:
           // React on Figure object dropped into IPPFIGURE_CONFORMTO
           else if (MSG_DESCRIPTION_CHECKUPDATE)
                DescriptionCheckUpdate*     dcu =          static_cast<DescriptionCheckUpdate*>(data);
      // +CRASH
                DescID descID =                              *(dcu->descid);
                if (descID[0].id == IPPFIGURE_CONFORMTO)
      // -CRASH
                     BaseDocument*               baseDoc =     node->GetDocument();
                     if (!baseDoc)                              return FALSE;
                     BaseContainer*               bc =          ((BaseTag* )node)->GetDataInstance();
                     if (!bc)                                   return FALSE;
                     if (!node->GetDescription(desc,0))     return FALSE;
                     BaseObject*     obj =          bc->GetObjectLink(IPPFIGURE_CONFORMTO, baseDoc);
                     if (obj)                    GePrint("Conform To: "+obj->GetName());
      I've tried (*(dcu->descid))[0] (no compile) and ((DescID)*(dcu->descid))[0] (crash) among others. Is there any way to get this dereferenced in order to apply the DescLevel operator!? It is the ONLY way to get at the DescLevel...
        On 04/03/2006 at 23:36, xxxxxxxx wrote:
        Ah, nevermind. I see that a similar dereference in the API code is commented out (wonders why...). I'll just use a darned BUTTON resource. 😉
