    First TagPlugin for Tutorial
    3 Posts 0 Posters 315 Views
      On 21/02/2006 at 14:15, xxxxxxxx wrote:
      Cinema 4D Version:   R9.5
      Hello all together,
      i try to learn c++ for C4D-Plugin programming.
      I had started a workshop: http://www.c4dboard.com/index.php?showforum=72
      And a VeryFirstSteps Tutorial (german), for free VisualC++ from MS (not publish up to now) : http://www.total3d.de/vcppp.pdf
      I learning by writing 🙂
      I thing the best way to learning and describe, ist to get a Plugin without a function, or with very very small-code for function.[b]I need a code for a very minimal Tag-Plugin.[/b]
      The Tag-Plugin in SDK look like to much.
      I don't understand, what is für TAG self, and what for doing what the Tag do.
      Here my my try to make a TAG without do something, but crashing:
      [b]why don't work the code ?[/b]
      http://www.total3d.de/mainTAG.zip
        On 22/02/2006 at 02:21, xxxxxxxx wrote:
        Your code seems fine. But your project lacks a description file. info is the name of the description file, so don't localize it.
        if (!name.Content()) return TRUE; // FALSE is better as something went wrong
        return RegisterTagPlugin(PLUGIN_ID,name,TAG_EXPRESSION|TAG_VISIBLE,DEINTAGPLUGIN::Alloc,"Deintag","DEINTAG_icon.tif",0);
        Now you only need a "res/description/Deintag.res", according .h and .str files. Look in the sdk for
        tlookatcameraexp.res/-.h/-.str and do it likewise.
          On 23/02/2006 at 08:07, xxxxxxxx wrote:
          Thanks for the answer!
          But i cant get it 😞
          I try to copy the res and .h from the SDK-File "tlookatcameraexp"
          It don't work.
          I use VisualC++ 2005 Express...
