    Undo question
    4 Posts 0 Posters 405 Views
      On 19/02/2006 at 11:40, xxxxxxxx wrote:
      Cinema 4D Version:   9.0+
      Howdy,
      Here's the problem:
      From a CommandData plugin, I'm adding 3 tags to the document and making one of them the active tag. This is all being done between a StartUndo()/EndUndo() call, but setting the tag as the active tag is not being logged into the undo group, and it takes two undos to undo the command.
      doc->StartUndo();
      //...allocate and add tagA code here
      doc->AddUndo(UNDO_NEW,tagA);
      //...allocate and add tagB code here
      doc->AddUndo(UNDO_NEW,tagB);
      //...allocate and add tagC code here
      doc->AddUndo(UNDO_NEW,tagC);
      doc->SetActiveTag(tagB);
      doc->EndUndo();
      I see there is an UNDO_ACTIVATE flag, but the SDK documentation says this:
      **UNDO_ACTIVATE
      Automatically managed by SetActiveObject()/Tag()/Material() etc. No need to use manually.**
      But it doesn't seem to add it to the undo group.
      I did try adding the line:
          doc->AddUndo(UNDO_ACTIVATE, tagB);
      ...both before and after the SetActiveTag() call, but neither one had an effect, and it still takes two undos to undo the command.
      Any ideas?
      Adios,
      Cactus Dan
        On 20/02/2006 at 04:32, xxxxxxxx wrote:
        Perhaps it makes a difference if you reverse the order to:
        .. create tagB
        you could also try to set the active bit manually.
        .. create tagB
        doc->AddUndo(UNDO_ACTIVEATE,tagB);
        tagB->SetBit(ACTIVE_BIT);
        i think this will most likely work. As well as this:
        .. create tagB
        but then you loose all the convenience of SetActiveTag(). Perhaps you must write your own SetActiveTag which adds all the selection undos to your undo block.
          On 20/02/2006 at 16:56, xxxxxxxx wrote:
          Howdy,
          Thanks Michael, for the reply, but I've since discovered that it's something else that's wrong, because if I comment out the line...
          //doc->SetActiveTag(tagB);
          ...it still needs two undos to undo the command. :o(
          I'm wondering if there is a problem because the actual program flow is like this:
          create tagA
          create tagB
          branch to initialize data in tagB
          create tagC
          ... I reckon I better put on the debugging hat.
          Adios,
          Cactus Dan
            On 20/02/2006 at 17:21, xxxxxxxx wrote:
            Howdy,
            AHA!
            I found the problem. It seems that you can't have a StartUndo()/EndUndo() nested within a StartUndo()/EndUndo(). The problem is that after adding tagC, I'm sending a MSG_DESCRIPTION_COMMAND to tagC to simulate the pressing of a button, but within that button's routine in tagC, there is another StartUndo()/EndUndo() group. If I don't send the message, then undoing the command works fine with only one undo.
            I reckon I'll have to add a separate routine to handle invoking that button from the command tool. ;o)
            Adios,
            Cactus Dan
