    Color Correction
    5 Posts 0 Posters 493 Views
      On 17/01/2006 at 05:02, xxxxxxxx wrote:
      Cinema 4D Version:   9.52
      Hello to all !!
      Can i make color correction on final render with Coffee or XPresso??
      Tnx in advance for the answer !
        On 22/01/2006 at 23:37, xxxxxxxx wrote:
        Hello ...
        I think VideoPostData plugin type may fill that requiremnt ...
        You can find VPInvertImage.cpp in the cinema4dsdk sample project ...
        That plugin change the final result of the render to a negative image ...
        Wishing you all the best ...
        ZawMinTun
          On 25/01/2006 at 04:28, xxxxxxxx wrote:
          VideoPostData is the way to go, though that is C++. There's no way to do it using C.O.F.F.E.E. or Xpresso.
            On 30/01/2006 at 03:31, xxxxxxxx wrote:
            Wouldn't it be possible to modify images with COFFEE if you load them as a basebitmap? Of course the filter would not be executed automatically after the render, but you could load the rendered image manually and then execute the filter?
            /Filip
              On 01/02/2006 at 00:52, xxxxxxxx wrote:
              Might be possible, but I'm confident that then People would prefer to use Bodypaint or Photoshop for that....
              Kabe
