    Script with Bone Tail doesn't rung
    3 Posts 0 Posters 489 Views
      On 11/01/2006 at 05:18, xxxxxxxx wrote:
      Cinema 4D Version:   9
      Dear Friends of Cinema 4D, I have found a coffee script of an bone tail, but it doesn't work. I have copied it from a cinema bood by sven hauth, I have got an error message in line 9 and 2. I have started since 4 days to understand the coffee language, I am a beginner with coffee scripts 🙂 bye, and perhaps somebody can help me, best regards to all cinema users, Frankolino 🙂
      Mistake and Fault in Line with "var opcnt..."
      // Script for BoneDirection "TailSpline" begins
      currentobjName = Get("Bone");
      Var opcnt=>15;
      Main(dock,op){
      Var op1=op;
      Var jsobj=doc->GetJS("TailSpline");
      sop->InitLength(1);
      var mat,smat=sop->GetMg(),pos,pos1,I=0.0,bc,rot;
      while (op1){
      I++;
      Pos=smat->GetMulP(sop->GetSplinePoint(sop->
       UniformTonatural((I-1)/opcnt),1));
      pos1=smat->GetMulP(sop->GetSplinePoint(sop->
       UniformTonatural((i)/opcnt),1));
      mat=op1->GetUpMg();
      mat->Invert();
      pos=mat->GetMulP(pos);
      pos1=mat->GetMulP(pos1);
      rot=VectorToHPB(pos1-pos) ;
      op1->SetRotation(rot);
      op1=op1->GetDown();
      // Script for BoneDirection "TailSpline" ends
      <file://===================>
        On 11/01/2006 at 06:24, xxxxxxxx wrote:
        For line 2: var opcnt = 15; (removed the '>'). Is that in the code or is it a typo?
        For line 9: I++ is illegal for real (floating point) values (only integral values). If you want to increment a real value, do this instead: I = I+1.0; If COFFEE supports it (not sure), you could do it shorthand: I += 1.0;
        HTH!
          On 11/01/2006 at 06:52, xxxxxxxx wrote:
          Hi Robert, very good! - I will try it. Many thanks! 🙂 Frankolino
