    xpresso
    3 Posts 0 Posters 377 Views
      On 22/12/2005 at 16:42, xxxxxxxx wrote:
      Cinema 4D Version:   c4d95sdk
      Language(s) :      XPRESSO  ;
      how does one use the 'node->RemoveUnusedPorts()' function.
      i am able to issue node->RemoveConnections().
      so now all wires have gone,
      but a next issued RemoveUnusedPorts() does nothing.
      thanks,
        On 02/01/2006 at 14:06, xxxxxxxx wrote:
        It seems to work here. Did you remember EventAdd()? Note that it only removes unused ports that *can* be removed, i.e. not mandatory ports. So for example on a Condition node it will remove all Input ports except one.
        Here's my code:
            XPressoTag* t = static_cast<XPressoTag*>(doc->GetFirstObject()->GetFirstTag());
            GvNodeMaster* nm = t->GetNodeMaster();
            GvNode* r = nm->GetRoot();
            GvNode* n = r->GetDown();
            n->RemoveConnections();
            n->RemoveUnusedPorts();
            EventAdd();
          On 04/01/2006 at 10:28, xxxxxxxx wrote:
          Did indeed forget the EventAdd but still can't
          get it going.
          Added the ports with AddPort, after AddPortIsOK.
          In the res file group I add more ports then i think i ever need, via LONG PORT_00 {OUTPORT; STATICPORT;}
          This is not very elegant, i can't find much about it.
          Can it be the trouble ?
          Should I use something dynamic?
          by the way, found that RemovePort(port,false) does work.
          regards,
