    attatch Tags
    20 Posts 0 Posters 2.2k Views
      On 03/10/2005 at 02:51, xxxxxxxx wrote:
      Thats work 🙂
      Greate.
      But I need Bone-Array as BoneObject structure.
      I am so silly? Or is it so heavy?
      I'm sorry, that I must ask again:
          var Bones, objc;
          setbone(vdoc, addname, Atag, Btag, Ctag)
           objc++;
           Bone[objc]=new(BoneObject);
           Bone[objc]->SetName(addname);
           vdoc->InsertObject(Bone[objc],NULL,NULL);
          main(doc,op)
          objc=-1;
          Bones = new(array,64);
          setbone (doc, "Arm[00]", NULL, NULL, NULL);
      Why doesn't work ?
      For thank you and all who helps other I write my learnings down:
      http://www.total3d.de/index.php?b=mmdocu&wo=viewkapitel&bo=10&ka=78#titel
        On 03/10/2005 at 05:33, xxxxxxxx wrote:
        1. Why doesn't work?
        2. And how can I add Mocca_IK Tags?
          Normal IK-tag works, Expresso-tags too.
        3. But how can I add Nodes and connections in Expresso Tag?
            2a) How can I copy a Tag from one Bone to another?
            C4D IK-tags works, Expresso-tags, too.
            On 04/10/2005 at 11:21, xxxxxxxx wrote:
            Is there a chance, or was the question to much ?
              On 06/10/2005 at 07:51, xxxxxxxx wrote:
              All right !
              That questions are answered by Maxon!
              Thanks for all your help!
              Very helpfull tipps - This was first time I learn Coffee !
              I'm glad about this forum 🙂
                On 14/10/2005 at 11:57, xxxxxxxx wrote:
                1. I don't see any direct problem. What error do you get?
                  2a) var newtag->GetClone(); bone2->InsertTag(newtag)
                  2,3) It's not possible to add Mocca_IK tags or to alter Xpressions in C.O.F.F.E.E.
                  On 23/11/2005 at 21:18, xxxxxxxx wrote:
                  @mikael sterner
                  you say its impossible to add MOCCA-IK tags through COFFEE.
                  But what about if i use a Plugin *.cof written in COFFEE, and use that plugin to create my starting scene with all the objects and their tags...
                  Is it then possible to create "foreign" tags??
                    On 23/11/2005 at 21:29, xxxxxxxx wrote:
                    And if your answer is no.
                    Is there a documented Fileformat-specification for the *.c4d file?
                    also NO?
                    i thought so
                      On 28/11/2005 at 11:43, xxxxxxxx wrote:
                      Yes, the answer is unfortunately no. To add Mocca_IK tags or to alter Xpressions you need to use C++.
                        On 28/11/2005 at 11:45, xxxxxxxx wrote:
                        There is no public documentation of the current c4d file format. Documentation for the file format used by C4D R5 is available here at PluginCafe, though this won't help you with Mocca_IK or Xpressions.
