    Bump Strength
    5 Posts 0 Posters 371 Views
      On 23/09/2005 at 11:55, xxxxxxxx wrote:
      Cinema 4D Version:   9.5
      Hi, does anybody know how to use the Bump Strength in C4D 9.5Her is part of my code that doesn't work
           mat->SetChannelState(CHANNEL_BUMP, TRUE);
          var Bmp = mat->GetChannel(CHANNEL_BUMP);
          var BmpBc = Bmp->GetContainer();
          BmpBc->SetData(CH_TEXTURE, BumpMap);
          BmpBc->SetData(CH_BRIGHTNESS,  0.12);   ---> Always 20% Bug???
          Bmp->SetContainer(BmpBc);
      Thank you.
        On 23/09/2005 at 14:18, xxxxxxxx wrote:
        It's not CH_BRIGHTNESS, it's BUMP_STRENGTH - go figure. 😉
          On 24/09/2005 at 00:22, xxxxxxxx wrote:
          I know, I've already tried:
          The value of BmpInt is 1.0
          I supposed the result would be 100% but it's always 20%
              BmpBc->SetData(BUMP_STRENGTH, BmpInt);       ---> Always 20% Bug???
          Any Idea???
            On 24/09/2005 at 08:54, xxxxxxxx wrote:
            According to the COFFEE 9.1 docs, you can't get there from there. 😉
            Container ID Type Explanation
            CH_COLOR [vector] Color vector
            CH_BRIGHTNESS [float] Brightness
            CH_TEXTURE [string] Texture name
            CH_BLUR_OFFSET [float] Blur offset
            CH_BLUR_STRENGTH [float] Blur strength
            CH_INTERPOLATION [int] Interpolation (see dialog)
            CH_MIXMODE [int] Mix mode (see dialog)
            CH_MIXSTRENGTH [float] Mix strength
            CH_TIME_FROM [int] Movie from
            CH_TIME_TO [int] Movie to
            CH_TIME_FPS [int] Movie framerate
            CH_TIME_MODE [int] Sequence mode (see dialog)
            CH_TIME_TIMING [int] Sequence timing (see dialog)
            CH_TIME_START [BaseTime] Sequence start
            CH_TIME_END [BaseTime] Sequence end
            CH_TIME_LOOPS [int] Sequence loops
            The Container only works with these settings common to channels.
            With the C++ SDK, one would use SetParameter(), but this isn't available in the COFFEE SDK. Have you tried this instead:
            BmpBc- >SetFloat(BUMP_STRENGTH,BmpInt);
              On 24/09/2005 at 09:01, xxxxxxxx wrote:
              Hi again,
              I found that the container was not the good one!!!
              Finally, this work:
                  var BmpIt = mat->GetContainer();
                  BmpIt->SetData(MATERIAL_BUMP_STRENGTH, BmpInt);
                  mat->SetContainer(BmpIt);
              Thank you.
              B->
