    UniformTonatural on PrimitiveSplines?
    2 Posts 0 Posters 279 Views
      On 09/09/2005 at 17:02, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      Platform:    Mac  ;
      A problem that makes me go round in circles.
      To get an even movement on a regular spline I use "UniformTonatural" option.
      It works fine like this:
      <CODE>var type1 = OBJ1->GetType();
      // Is Spline
      if ( type1 == 5101)
      println("OBJ1 Is Spline");
      OBJ1->InitLength(0 );
      var spos1 = OBJ1->GetSplinePoint(OBJ1->UniformTonatural(POS1) , 0);
      op->SetPosition(OBJ1->GetMg()->GetMulP(spos1));
      OBJ1->FreeLength();
      else
      </CODE>
      I can not for the life of me get the same thing to happen when using a PrimitiveSpline,
      like Rectangle, Cogwheel etc.
      The same principle as with a regular spline doesn't seem to apply. I got it working with the default function, that is, it moves slow in the corners and fast on straighter parts.
      Like this(InitLength and FreeLength are commented here).
      <CODE>/// Is Primitive Spline
      if ((type1>5174 && type1<5190))
      println("OBJ1 Is PrimitiveSpline");
      //OBJ1->GetSplineObject()->InitLength(0);
      var spos1 = OBJ1->GetSplineObject()->GetSplinePoint(POS1 ,0); // <<How to implement UniformTonatural here??
      //OBJ1->GetSplineObject()->FreeLength();
      else</CODE>
      I've tried all possible settings and combination based on the previous example I can think of, but no go....
      Any input is most welcome.
      Lennart
      PS UniformTonatural doesn't get spelled correctly when posting it.
      It is spelled correct in my code with a big "N". DS
        On 10/09/2005 at 13:53, xxxxxxxx wrote:
        Not to make another cliffhanger with no answer/solution, I got this working with the help of mdme_Sadie and JDP over at CGTalk.
        var myspline=OBJ1->GetSplineObject();
        if (!myspline) return FALSE;
        if (!myspline->InitLength(0)) return FALSE;
        var pos=myspline->GetSplinePoint(0.5,0);
        as well as:
        var op = OBJ1->GetSplineObject();
        op->InitLength(0);
        Lennart
