    CommandNotify
    7 Posts 0 Posters 552 Views
      On 04/09/2005 at 13:00, xxxxxxxx wrote:
      Cinema 4D Version:
      anybody used the 'CommandNotify' func?
      can't find anything about it.
      Just want a notification if a c4D file is loaded (new doc)
      I'm working in a commandplug, in a dialog
      regards,
        On 06/09/2005 at 12:50, xxxxxxxx wrote:
        Now i see that its only called when something in the dialog onwn menu happens.
        I need to be called when main C4D is going to load and or save's a doc.
        Who know's how to do that ?
        regards,
          On 08/09/2005 at 01:20, xxxxxxxx wrote:
          Ok,
          I'm in a commandata plugin, or in a tagdata plug.
          How do i know if the document is going to be saved ?
          In a tag i can use Read(), but: this is going to be called for every tag. I want only one call to initialize some data.
          I could use an incrementing global counter and take action when its zero, but, that's not very elegant.
          Then: how do i know it in my commanddata plug ?
          Is there a message or a call i overlooked ?
          kind regards,
            On 13/09/2005 at 08:35, xxxxxxxx wrote:
            bump
              On 14/09/2005 at 13:17, xxxxxxxx wrote:
              Listen for the document info message:
                  virtual Bool Message(GeListNode* node, LONG type, void* data)
                      if (type == MSG_DOCUMENTINFO)
                          DocumentInfoData* info = static_cast<DocumentInfoData*>(data);
                          if (info && info->type == MSG_DOCUMENTINFO_TYPE_SAVE_BEFORE)
                              GePrint("Document is about to be saved!");
                      return TagData::Message(node, type, data);
                On 15/09/2005 at 15:04, xxxxxxxx wrote:
                Ok, thanks Mikael.
                But as i said: in a tag i can use Read()
                But that is going to be called for every tag.
                I want only one call.
                I use a master commanddata plug for management.
                How can i catch this 'document info message' now, here is no type member.
                Regards,
                  On 14/10/2005 at 03:53, xxxxxxxx wrote:
                  You can create a SceneHookData plugin to catch this in NodeData::Message().
