    Renderdocument renders whole animation
    1 Posts 0 Posters 170 Views
      On 02/09/2005 at 02:02, xxxxxxxx wrote:
      Cinema 4D Version:   9.102
      If I don't set
      rdata.SetLong(RDATA_FRAMESEQUENCE, 1); // actual frame only
      and update the rendering sequence step by step with:
      BaseTime bt = BaseTime(starttime + newOffset);
         m_dlg->m_doc->SetTime(bt);
         m_dlg->m_doc->AnimateDocument(this->Get(), TRUE, TRUE);
         EventAdd(EVENT_FORCEREDRAW);
      the RenderDocument(...) starts rendering the whole
      animation, as given in the rendersettings (i.e. frames 0-100). This is obvious by the time, it takes (2times with 2 frames, 10times with 10 frames and so on).
      But the Renderdocument can only output single BaseBitmaps, while rendering all 100 frames.
      In the end it puts out the last rendered image.
      I'm running the RenderDocument in a Thread.
      Is there a special event that occurs when RenderDocument has finished the next frame?
      Or am I totally wrong-going???
