    error C2653: 'SUPER' : no class or na...
    5 Posts 0 Posters 464 Views
      On 28/08/2005 at 04:11, xxxxxxxx wrote:
      Cinema 4D Version:   8.503
      I just want to add some drawings to my plugin object. The SDK docs tell, one has to add a call to the parent of the draw function by including
      return SUPER::Draw(op, drawpass, bd, bh);
      at the end of the function. But this ends with a comiler error (MS VC++ 6) :
      error C2653: 'SUPER' : no class or namespace
      What am I doing wrong? I didn't find any definition of "SUPER" in the h files...
        On 28/08/2005 at 08:26, xxxxxxxx wrote:
        you need to use the parent class instead of SUPER. If you have an object then use ObjectData::Draw(...)
          On 30/08/2005 at 03:54, xxxxxxxx wrote:
          You needed to define the INSTANCEOF in your class, then you can use SUPER. It makes it much easier to do changes later on rather then directly referencing a class name. (see the SDK DoubleCircle example)
            On 30/08/2005 at 10:41, xxxxxxxx wrote:
            Thanks. But the Draw routine of doublecircle just returns TRUE (as I also always did by now) :
            Bool DoubleCircleData::Draw(PluginObject *op, LONG type, BaseDraw *bd, BaseDrawHelp *bh)
                 if (type!=DRAWPASS_HANDLES) return TRUE;
                 BaseContainer *data = op->GetDataInstance();
                 Matrix m = bh->GetMg();
                 bd->SetPen(GetWorldColor(COLOR_ACTIVEPOINT));
                 bd->Handle3D(GetRTHandle(op,0)*m,HANDLE_BIG);
                 bd->Line3D(GetRTHandle(op,0)*m,m.off);
            What I mean, is the advice in the sdk docs:
            Draw additional information for your object in the editor. Be sure to call the parent version by including this call at the end of the function:
            Or do I missunderstand something?
              On 30/08/2005 at 14:10, xxxxxxxx wrote:
              Take a look at the class definition, I was referring to the INSTANCEOF and how to use it so you can reference the SUPER marco. Generally it is best to call the SUPER::function and leave it as the default unless you want to be sure a certain value (non-default) is returned (i.e. on error etc.).
