    Object Creation with COFFEE
    9 Posts 0 Posters 715 Views
      On 18/08/2005 at 14:56, xxxxxxxx wrote:
      Cinema 4D Version:   9.012
      Platform:      Mac OSX  ;
      Hey out there.
      I am trying to find out how to create new objects with COFFEE. Should be simple, but I can't seem to find any examples in the SDK or online forums.
      I am trying to use AllocObject(), but can't figure out the syntax. I'm a newbie to COFFEE and I just need some help getting started. Any assistance would be much appreciated.
      -Cheers
        On 18/08/2005 at 15:48, xxxxxxxx wrote:
        Go grab yourself the COFFEE documentation!
        Plugin Cafe Downloads[URL-REMOVED]
        Since you are MacOS, get the HTML version, not the CHM Windows help file.
          On 18/08/2005 at 16:00, xxxxxxxx wrote:
          I have the documentation. I'm finding it a bit cryptic, and there are no examples of how to do what I want to do. AllocObject is not a member of BaseObject, understandably, but when I try the following:
          var cam = new(BaseObject);
          or:
          var cam = new(AllocObject(Ocamera));
          I get errors. I know that there is something basic about the object method that I'm just not grasping. I need help. Thank you.
            On 18/08/2005 at 19:03, xxxxxxxx wrote:
            Try this:
            var cam = AllocObject(Ocamera);
              On 19/08/2005 at 10:31, xxxxxxxx wrote:
              I've tried this as well. I get an error, "Variable or function expected" at the type call to AllocObject.
              Thanks.
                On 19/08/2005 at 13:05, xxxxxxxx wrote:
                Okay. What you may need here is this then:
                var type = Ocamera;
                var cam = AllocObject(type);
                I haven't used the 9.1 version of COFFEE yet, but the doc says ([int] type), so I expect that one cannot use the type directly. Examples of the changes in 9.1 would be warranted.
                  On 19/08/2005 at 17:32, xxxxxxxx wrote:
                  Robert, thanks for your help. I'm still geting an error though. At the end of the first line I still get, "Variable or function expected."
                    On 19/08/2005 at 21:56, xxxxxxxx wrote:
                    Something must be incorrect somewhere else then. My second message had the correct methodology. Here's a simple test source (MenuPlugin) - it loads an icon, so you may want to dump some tif or jpg image as the one mentioned in main() to avoid complaints. Also, use your own Plugin_ID for PLUGIN_MENU_ID.
                    This worked perfectly. Calling the plugin from the Plugins menu created a Camera object.
                    // allocobject.cof
                    // Included symbols
                    //include "c4d_symbols.h"
                    enum
                         // Unique ids from http://www.plugincafe.com
                         PLUGIN_MENU_ID = xxxxxxx,
                         _DUMMY02_
                    var resource;
                    var plugin_path;
                    var plugin_icon;
                    // CLASS: Drop To Floor Menu - Register plugin in menu
                    class AllocObject_MenuPlugin : MenuPlugin
                         private:
                              AllocObject_MenuPlugin();
                              GetID();
                              GetIcon();
                              GetName();
                              GetHelp();
                              Execute(doc);
                    AllocObject_MenuPlugin::AllocObject_MenuPlugin()     { super(); }
                    AllocObject_MenuPlugin::GetID()                                   { return PLUGIN_MENU_ID; }
                    AllocObject_MenuPlugin::GetName()                              { return "AllocObject"; }
                    AllocObject_MenuPlugin::GetHelp()                              { return "Help"; }
                    AllocObject_MenuPlugin::GetIcon()                              { return plugin_icon; }
                    AllocObject_MenuPlugin::Execute(doc)
                         StatusSetText("AllocObject");
                         var camera;
                         var document;
                         if (!(camera = AllocObject(Ocamera))) return FALSE;
                         document = GetActiveDocument();
                         StatusSetText("");
                         if (!document->InsertObject(camera, NULL, NULL)) return FALSE;
                         EventAdd();
                    // Start of plugin
                         // Load Resource
                         if (!(plugin_path = GeGetRootFilename())) println("Unable to find plugin!");
                         plugin_path->RemoveLast();
                         // Load Icons
                         var icon_file = plugin_path->GetClone();
                         icon_file->AddLast("pluginicon.tif");
                         plugin_icon = new(BaseBitmap,1,1);
                         plugin_icon->Load(icon_file);
                         // Register Plugins
                         Register(AllocObject_MenuPlugin);
                      On 22/08/2005 at 15:40, xxxxxxxx wrote:
                      Robert,
                      Thank you so much for all your help. Your example was very useful as an addition to those that come with the SDK, so thanks.
                      I was still getting an error, and found that the real problem all along was that I hadn't installed the 9.102 updater from 9.012. So I had really been using the right syntax from early on, but the AllocObject() command was giving an error regardless. Now that I've installed the updater, everything is fine.
                      Sorry that I overlooked this, and thank you for taking time out to help me.
                      -Aaron
