    64 bit compiled on 32 bit machine?
    8 Posts 0 Posters 707 Views
      On 13/08/2005 at 20:48, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      Howdy,
      Using VS 2005 on a 32 bit machine, I can't seem to create an x64 solution in the Configuration Manager like the 64-bitMigration.pdf file tells me to do.
      I get an error message that says:
      "New project platforms cannot be created because this new solution platform is not supported by any of the projects."
      I thought we were supposed to be able to compile a 64 bit version on our 32 bit machines.
      Adios,
      Cactus Dan
        On 13/08/2005 at 21:37, xxxxxxxx wrote:
        Howdy,
        DOH! Never mind.
        Adios,
        Cactus Dan
          On 14/08/2005 at 10:58, xxxxxxxx wrote:
          Howdy,
          Well, it still doesn't work. Please cancel my "Never mind"
          Anyway the migration pdf file says I should be able to compile the 64 bit version on a 32 bit machine, but it looks like it only walks you through setting it up for compiling on a 64 bit machine.
          I did get it to compile, but when I sent the .cdl64 file to someone with a 64 bit machine to test, it didn't work.
          Any ideas?
          Adios,
          Cactus Dan
            On 10/12/2008 at 03:46, xxxxxxxx wrote:
            Quote: Originally posted by Cactus Dan on 13 August 2005
            > User Information:
            > Cinema 4D Version:   9.1 </br>Platform:   Windows  ;   </br>Language(s) :    C++  ;  </br>
            > Howdy,
            > Adios,
            > Cactus Dan
            I have the same problem with VS 2008. Did you find a solution?
            Thanks.
              On 10/12/2008 at 03:51, xxxxxxxx wrote:
              hmm, cannot confirm. I always compile my 64-Bit versions on a 32-Bit system. I also simply followed the migration pdf. And you get no errors? strange. 😕
                On 10/12/2008 at 04:05, xxxxxxxx wrote:
                Hi!
                VS2005 is a cross compiler and should be able to compile your plugin to a 64bit version. I'd never done that because I use a 64bit system, but I can confirm its possible.
                bye..
                  On 10/12/2008 at 07:49, xxxxxxxx wrote:
                  Howdy,
                  in this thread we finally worked it out:
                  64 bit compile solved
                  I hope that helps.
                  Adios,
                  Cactus Dan
                    On 16/12/2008 at 07:58, xxxxxxxx wrote:
                    Quote: Originally posted by Cactus Dan on 10 December 2008
                    > Howdy,
                    > I hope that helps.
                    > Adios,
                    > Cactus Dan
                    Thanks to all, I'll try to resolve the problem with this topic.
