    Raytracing Perspective Glitches?
    10 Posts 0 Posters 714 Views
      On 06/05/2005 at 05:09, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      Morning!
      I'm currently testing a few shader ideas out using the TraceGeometry command in the VolumeData struct, but am having some weird results. When I transform the current ray for objects near the camera they seem skewed like the scene is being viewed thru a fish-eye lens! Is this a perspective effect, and has anyone experienced this at all?
      Ta
      Dan
        On 09/05/2005 at 01:14, xxxxxxxx wrote:
        no, haven´t experienced this yet.
          On 10/05/2005 at 02:35, xxxxxxxx wrote:
          Oh, ok. Might be something to do with the way I'm transforming the ray I guess?
            On 10/05/2005 at 06:06, xxxxxxxx wrote:
            Without some more information we'd all be guessing 😉 maybe you could post a code snip or at least what transform you are doing to the ray.
              On 11/05/2005 at 07:40, xxxxxxxx wrote:
              Hi David
              I maybe be doing something really stupid when transforming the ray, perhaps my 3d maths need polishing up a bit! I'll probably need to go into some depth to explain what is going wrong, and you contactable? Or could you mail me please?
                On 11/05/2005 at 07:49, xxxxxxxx wrote:
                You would be better off posting here, this way someone with the right experience might know an answer plus it helps everyone else if they come across a similar problem.
                  On 11/05/2005 at 10:24, xxxxxxxx wrote:
                  Ok fair enough. Basically to summarise in a reasonable amount of code ...
                  The code below gets the current ray, transforms it to another objects inverted global matrix (got using ->GetMg), then checks whether the new ray intersects or not (so if hit, col=white, else col=black) - see below :
                  [CODE}
                  Ray *ray, invray;
                  ray = vd->ray;
                  Vector pos = SV(ray->p);
                  Vector dir = SV(ray->v);
                  Vector newpos = globalMat * pos;
                  Vector newdir = globalMat * dir;
                  invray.p = LV(newpos);
                  invray.v = LV(newdir);
                  vd->TraceGeometry(&invray;, MAXREAL, 0, &p;, &n;, &hit;);
                  if(hit)
                  vd->col = Vector(1.0, 1.0, 1.0);
                  else
                  vd->col = Vector(0.0, 0.0, 0.0);
                  {/CODE]
                  Does this help explain whats going wrong at all?
                  Cheers ...
                    On 12/05/2005 at 08:37, xxxxxxxx wrote:
                    Hi
                    direction vectors are usually transformed by
                    newdir = dir^globalMat;
                    This omits the translation.
                      On 12/05/2005 at 09:15, xxxxxxxx wrote:
                      Cheers Michael, will give that a go ...
                        On 13/05/2005 at 01:30, xxxxxxxx wrote:
                        Wow! That worked like a treat. Still a little bit of weirdness going on in the distance, but probably my maths!!
                        Excellent Michael, thanks!
