    AutoAddSequence returns NULL. Why?
    4 Posts 0 Posters 361 Views
      On 17/04/2005 at 04:42, xxxxxxxx wrote:
      Cinema 4D Version:   9.1 Demo
      Hello...
      I have a problem with the AutoAddSequence method. I want to check if there is still a sequence. If not, the program should add a sequence to the track. I use the CreateKey method which I have found in the MorphMixer.cpp example. Now, in some cases, this method returns NULL because no sequence could be added.
      See this:
      static AnimValue* CreateKey(BaseDocument *doc, BaseObject *op, const BaseTime &time;, LONG index, LONG sid, Real value)
           // check if track exists
           BaseTrack *track = op->FindTrack(DescID(DescLevel(index), DescLevel(sid, DTYPE_REAL,0)));
           if (!track)
                track = AllocValueTrack(op,DescID(DescLevel(index), DescLevel(sid, DTYPE_REAL,0))); if (!track) {return NULL;}
                op->InsertTrackLast(track);
           // check for sequence
           BaseSequence *seq=NULL;
           for (seq = track->GetFirstSequence(); seq; seq=seq->GetNext())
                if (time>=seq->GetT1() && time<=seq->GetT2())
                     break;
           if (!seq)
                seq = track->AutoAddSequence(doc,time);
                if (!seq) {/*MessageDialog("no seq" + RealToString(time.Get()));*/return NULL;}
           BaseKey *key = BaseKey::Alloc(seq->GetType()); if (!key) {return NULL;}
           AnimValue *av = GetKeyValue(key); if (!av) {return NULL;}
           av->value = value;
           key->SetTime(time);
           seq->InsertKey(key);
           return av;
      Why doesn't AutoAddSequence() work? Why isn't a sequence added?
      Can you help me?
      Regards,
      jacqui.
        On 21/04/2005 at 13:33, xxxxxxxx wrote:
        Any special sequence configurations that cause this error, or is it totally random?
          On 05/07/2005 at 10:55, xxxxxxxx wrote:
          When I open an empty project in Cinema4D and call this plugin, which generates a new animation sequence, I get this error, that means this method returns NULL.
          When I again call this plugin (i.e. this method) while the same Cinema4D project is open, it works...!?
            On 05/07/2005 at 11:28, xxxxxxxx wrote:
            I'm surprised it doesn't crash! It is entirely possible for 'op' to be NULL. Unless you are ensuring that before calling CreateKey(). Has 'op' been BaseDocument->InsertObject(op,etc.)'d before calling the method?
