    Read one point Selection and...
    3 Posts 0 Posters 340 Views
      On 23/03/2005 at 03:32, xxxxxxxx wrote:
      Cinema 4D Version:
      Hello to all !!
      Two question:
      1. how i can read point position of one saved point selection (set selection)?
      2. How i can read the mirror axis of the simmetry object?
      Tnx in advance for the answer !
        On 24/03/2005 at 10:32, xxxxxxxx wrote:
        1. You need to get the selection tag of the object.
        First get the first tag.
        Then get through all tags with GetNext() and check if it is a PointSelectionTag.
        Sth like (pseudocode) :
        var found = FALSE;
        var tag = obj->GetFirstTag(); if(!tag) return;
        while(tag!=NULL) //or tag!=DA_NIL
            if(tag->GetType()==PointSelectionTag){
               found = TRUE;
               break;
            tag = tag->GetNext();
        if(!found) return;
        if found is true, the tag is a pointselection tag. you can now get the selected points and go through the point array.
        var sel = tag->GetSelection(); if(!sel) return;
        var i;
        for (i = 0; i < obj->GetPointCount(); i++)
        if (select->IsSelected(i))
            //This is the point position
            var p = obj->GetPoint(i);
        1. the mirror axis is the position of the symmtry object.
          Get it from the global matrix:
        var m = obj->GetMg();
        var m_axis = m->GetV0();
        HTH
        Katachi
          On 25/03/2005 at 00:02, xxxxxxxx wrote:
          Tnx to all Katachi !! :))
