    ray->vv and ray->pp?
    7 Posts 0 Posters 666 Views
      On 22/03/2005 at 07:36, xxxxxxxx wrote:
      Cinema 4D Version:   9.1
      why are the vd->ray->vv and vd->ray->pp vectors never filled? Do I need to fill them myself? If so, how are they filled?
      Katachi
        On 25/03/2005 at 06:20, xxxxxxxx wrote:
        Do you have MIP-mapping enabled for the shader? Where are you accessing these vectors? Are ->v and ->p filled?
          On 25/03/2005 at 06:24, xxxxxxxx wrote:
          I did so, but it doesn´t help. However, I believe it may be may fault. I am accessing them from within a volume shader with no surface calculation (it´s an environment shader).
          I guess that´s why they are not filled? ->v and ->p are filled.
            On 25/03/2005 at 12:51, xxxxxxxx wrote:
            I guess I should have been more explicit, but did you set SHADER_MIPSAT in MaterialData::GetRenderInfo()?
              On 25/03/2005 at 12:53, xxxxxxxx wrote:
              If you did that, then your explanation sounds likely.
                On 25/03/2005 at 13:49, xxxxxxxx wrote:
                yes, I did set SHADER_MIPSAT. If I´d like to fill them, is there a general rule of thumb what they should look like?
                  On 25/03/2005 at 13:50, xxxxxxxx wrote:
                  just to add: spot size etc. are of course not accessible either (resp. not filled)
