    Beginner-Problem: Examples don't work!
    2 Posts 0 Posters 218 Views
      On 21/03/2005 at 07:46, xxxxxxxx wrote:
      Cinema 4D Version:   9.1 Demo
      Hello...
      Today, I read something about COFFEE as a possibility to write plugins for C4D. So, I decided to learn it. I've made some tutorials. After a while, the first example works. This very simple one:
      println("Hello World!");
      But when I want to use other examples, I always get COFFEE Errors in the console window.
      F.ex.:
      // Opens the above dialog with an exclamation mark icon
      var result = TextDialog("Hello World!", DLG_OKCANCEL + DLG_ICONEXCLAMATION);
      // Checks the result
      if (result == DLG_R_OK)
      TextDialog("You pressed OK!", DLG_OK);
      COFFEE ERROR!
      (124) Syntax Error
      File: test2.cof
      Line: 2
      Row: ~25
      I have tested a lot of examples, but I always get such errors like "(118) Variable or function expected". What's wrong?
        On 25/03/2005 at 06:22, xxxxxxxx wrote:
        Did you put the code within a function block? You can't just have it stand-alone in the file. The simplest function block is the "main" you had in the first sample. A more interesting variant is to use MenuPlugin::Execute().
