    Drawing in the editor
    18 Posts 0 Posters 1.7k Views
      On 13/07/2006 at 01:27, xxxxxxxx wrote:
      nope, still not possible.
        On 13/07/2006 at 06:24, xxxxxxxx wrote:
        Damn!! Instead of adding criptic stuff that is seldom used why aren't those more "in-you-face" aspects improved?
        This is a rethorical question, of course, not a direct question to any of you two ๐Ÿ˜‰
        Well, thank you anyway. I guess I must go on waiting... or bite the bullet and try out some C++ stuff. The problem is that the only free compiler I have available (not yet installed, though) is the XCode one. Will it produce Windows/Mac compiles? I believe not... and I also suspect that the plug-ins compiled by it will only run on the XCode-compiled version of Cinema4D. Correct me if I'm wrong, please ๐Ÿ™‚
        Rui Batista
          On 13/07/2006 at 06:32, xxxxxxxx wrote:
          Howdy,
          Yep, you are correct, you'll need Codewarrior for PPC versions, and you'll need MSVC++ for Windows versions.
          Adios,
          Cactus Dan
            On 13/07/2006 at 11:31, xxxxxxxx wrote:
            Well, I will only be producing stuff for Mac, then... And, at first, only for XCode. I'm not a real developer so I can't justify the purchase of a compiler. And DEFINETELLY, not a compiler for PC.
            Thank you for the information, Dan ๐Ÿ™‚
            Rui Batista
              On 13/07/2006 at 11:50, xxxxxxxx wrote:
              Howdy,
              Well, I could see the PPC versions of Cinema 4D eventually being phased out, although, I will sorely miss Codewarrior as a C++ development environment. MSVC++ is, for me, a nightmare to work with. That's why I develop on the Mac and only port to the PC. ๐Ÿ˜‰
              Adios,
              Cactus Dan
                On 14/07/2006 at 07:49, xxxxxxxx wrote:
                Hy folks,
                I read your topic here and took (just a quick) look at the C++ SDK 9.6. Is it right, that it would be possible to extend the C.O.F.F.E.E.-lanugage by own C++ classes? If so, perhaps it might be a good Idea to try that out to get access to functions not available in C.O.F.F.E.E because later on you do not need to to the same C++-coding again all the time, but reuse your code. In this case it might be a good idea to create extensionclasses for Mac and Pc and do the rest with C.O.F.F.E.E once.
                I will take a closer look at that and tell you here if I find something interesting.
                Ebiwahnkenobi
                  On 14/07/2006 at 08:07, xxxxxxxx wrote:
                  Thank you very much. I'll be waiting for your "report" ๐Ÿ™‚
                  Rui Batista
                    On 17/07/2006 at 07:22, xxxxxxxx wrote:
                    Hy Rui,
                    If you take a closer look at the 96SDK for C++,there is a class COFFEE. This class is designed to extend COFFEE. Your must add Functions and other parts by ADD-Commands that give a pointer for the procedure/function to be executed. I am not sure, if this must be a COFFEE-Script being pointed at or might be a C++-function too. In the second case, you should be able to write a new class given the ability to draw in the editor via c++ generally.I am sorry, that I did not try this out so far, but I do not have/use ย V-Studio so far. If I do so (and might be I will), of course I will post my experiences here.
                    ย
                    Ebiwahnkenobi
                      On 17/07/2006 at 08:44, xxxxxxxx wrote:
                      Howdy,
                      It might be a difficult task. I'm not all that experienced as a C++ programmer, but if my understanding of the SDK is correct, all drawing to the viewport is performed through an internal function. The plugin hook data types that allow drawing, have a virtual function Draw() included in the class that has the active BaseDraw pointer passed to it. That gives you access to the BaseDraw functions like: Point3D(), Line3D(), Polygon3D(), etc.
                      In the SDK docs under "Important Threading Information" it says that the Draw() function is a threaded function, so I'm assuming that drawing to the viewport has to be performed during the execution of that particular thread. I'm not sure how you'd go about accessing that thread, and from what I read in that section, it sounds like risky business.
                      Adios,
                      Cactus Dan
                        On 17/07/2006 at 08:55, xxxxxxxx wrote:
                        Hy Cactus Dan,
                        hm, I am honest I did not look at the drawing function before writing this, I had my focus on extension of the Coffe-language in general. I will look at it, but what you tell hereย is generally correct. I know from other languages that it is always very difficult to communicate between different threads due to their own adress-space and nosynchron running. There has to be some kind of callback-message to work with, otherwise it will be very risky or very slow.
                        (I do not think a call to StopAllThreads would really help, cause I do not know how they resume afterwards)
                        Thanks for your hint.
                        ย
                        Ebiwahnkenobi
                          On 17/07/2006 at 09:03, xxxxxxxx wrote:
                          Howdy,
                          There are some thread functions available for developers, but I don't know that much about threading. I only know enough about it from that section I read, to know why my plugin crashes when I do something wrong during a threaded function. ๐Ÿ˜‰
                          Adios,
                          Cactus Dan
