    BFM_DRAGRECEIVE, ListView, & Cursor
    2 Posts 0 Posters 261 Views
      On 06/03/2005 at 16:38, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Questions stacking up! ;0)
      For some unknown reason, it is impossible to set the mouse pointer during drag receive operations in my GeDialog's SimpleListView object. Here's the code; what's wrong with it? Is there a different approach for the SimpleListView (that was, perhaps, never illustrated anywhere) :
      LONG Message(...)
           // Drag and Drop
           else if (id == BFM_DRAGRECEIVE)
                Bool dropArea = CheckDropArea(IS_MATLISTVIEW, msg, TRUE, TRUE);
                SetDragDestination((dropArea)?MOUSE_POINT_HAND:MOUSE_FORBIDDEN);
                if (dropArea)
                     // Material drop
                     if (msg.GetLong(BFM_DRAG_FINISHED))
                          LONG type = 0;
                          void *object = NULL;
                          GetDragObject(msg, &type;, &object;);
                          if (object && (type == DRAGTYPE_ATOMARRAY))
                               AtomArray* array = static_cast<AtomArray*>(object);
                               Atom *atom;
                               type = array->GetCount();
                               for (LONG i = 0; i < type; i++)
                                    if ((atom = array->GetIndex(i)) && atom->IsInstanceOf(Mmaterial))
                                         Material* mat = static_cast<Material*>(atom);
                                         // - Set Item
                                         BaseContainer data;
                                         data.SetString('name', "Empty");
                                         matListView.SetItem(0, data);
                                         GePrint("Dropped: "+mat->GetName());
                               BaseContainer actionmsg(BFM_ACTION), actionresult;
                               actionmsg.SetLong(BFM_ACTION_ID, IS_MATLISTVIEW);
                               GeDialog::Message(actionmsg, actionresult);
      Yes, there is a return GeDialog::Message(...) at the end of the method.
      Thanks and confused.
        On 06/03/2005 at 22:30, xxxxxxxx wrote:
        No need to bother as I've decided on a different approach using a GetDDescription in the PluginMaterial to collect/update and pass all of the Materials to the dialog's listview. Much cleaner. 🙂
        But if there is an answer, it may help others who encounter a similar situation.
