    What element did I clicked on?
    9 Posts 0 Posters 808 Views
      On 04/03/2005 at 07:08, xxxxxxxx wrote:
      Cinema 4D Version:   8.x
      I finaly got the scrolling list of items working (more or less 😉
      I populated it with text, using AddStaticText.
      Now, how do I get to know in what element the user clicked?
      Until now I wrote this:
      PluginDialog::Message(msg)
      {var dev,chn;
      dev = msg->GetData(BFM_INPUT_DEVICE);
      if (dev == BFM_INPUT_MOUSE)
         chn = msg->GetData(BFM_INPUT_CHANNEL);
         if (chn == BFM_INPUT_MOUSELEFT)
              ***WHAT GOES HERE???***
         return super::Message(msg);
      Each static item has its own ID. Is there any way to know what was the clicked static text item?
      Rui Batista
        On 04/03/2005 at 07:32, xxxxxxxx wrote:
        You can use GeDialog::GetItemHeight() etc. to know where each fieldis. Then you have to check the X/Y position of the event (look in the container) against this for each ID.
          On 04/03/2005 at 07:35, xxxxxxxx wrote:
          My text is inside a Scroll group. What if I have the scroll slider on another position?
          Rui Batista
            On 04/03/2005 at 07:37, xxxxxxxx wrote:
            GetVisibleArea()
              On 04/03/2005 at 07:58, xxxxxxxx wrote:
              Thank you Mikael. Will give it a try 🙂
              Rui Batista
                On 04/03/2005 at 10:27, xxxxxxxx wrote:
                Ok, I have this:
                GetVisibleArea(GROUP_SCROLL,&x;,&y;,&w;,&h;);
                h=GetItemHeight(5000);
                click=msg->GetData(BFM_INPUT_Y);
                selected=ceil((y/h)-(click/h));
                Item with ID 5000 is the Static Text item. They are all the same size. Must I add it any other value? Like, the spacing between group elements?
                How can I identify which one was clicked?
                Also, when I resize the window down and the scroll group shows a slider, it gets tougher to click on item as the cursor tends to change into a hand, to scroll. Can that be turned off?
                Rui Batista
                  On 04/03/2005 at 10:32, xxxxxxxx wrote:
                  When I said etc. I meant the other GetElement...() functions described in the documentation. For example GetElementX().
                  You might be able to avoid the cursor change by using SetMousePointer(). I haven't tried, so perhaps it doesn't work or flickers. In that case the answer is no.
                    On 04/03/2005 at 10:41, xxxxxxxx wrote:
                    "When I said etc. I meant the other GetElement...() functions described in the documentation. For example GetElementX()."
                    Now you got me, Mikael. I can't find and GetElement... in the docs. I only have Static Text items inside the scroll group. And they are all simple filenames, so they are short (single line strings).
                    Rui Batista
                      On 04/03/2005 at 11:12, xxxxxxxx wrote:
                      When I said Element, I meant Item... 🙂
                      Have a look in the docs for GeBaseDialog. You'll find lots of useful functions in there.
