    Problem getting Material of PluginShader
    2 Posts 0 Posters 230 Views
      On 27/02/2005 at 15:21, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      Trying to get the Material for a PluginShader from within ShaderData.Init() (my own shader plugin). The code below always returns h == NULL and returns FALSE. The PluginShader GeListNode has no GeListHead? If I'm trying too early, where else, praytell, would I be able to do this?
           PluginShader *ps = (PluginShader* )node;
           // Get Shader's Material (hack)
           GeListHead* h;
           if (!(h = ps->GetListHead())) { GePrint("iShader.Init.h"); return FALSE; }
           material = static_cast<Material*>(h->GetParent());
           if (!material || (material->GetType() != Mmaterial)) { GePrint("iShader.Init.material"); return FALSE; }
        On 27/02/2005 at 16:59, xxxxxxxx wrote:
        Well, I found a hack of my own.
        There is only one message sent to the ShaderPlugin (into ShaderData) that isn't repeated twenty times - gad, you guys need to fix this (if you haven't in later SDK versions) - MSG_DESCTIPTION_INITUNDO. This allows me to grab the material (as above - yes, it works there, but not in ShaderData.Init()) and do my thing.
