    RenderDocument - Render Animation
    2 Posts 0 Posters 184 Views
      On 18/02/2005 at 06:18, xxxxxxxx wrote:
      Cinema 4D Version:
      Well, I'm somehow stuck again.
      I've figured out how to render an image but I can't render a whola animation (or some frames).
      Even if I try and get the RenderData from the document (and set it to render 5 or 6 frames) it just saves one single image.
      I've tryed with own Render settings, created a BaseContainer called RSettings and used SetData to manually set RDATA_FRAMEFROM ect. but it just doesn't work.
      I'm pretty sure this is just a simple and stupid mistake on my side but I just can't figure it out.
      Here is the code:
      BaseDocument *doc = GetActiveDocument();
      CamImage = BaseBitmap::Alloc();
      CamImage ->Init(width, height, 32);
      RenderDocument(doc, doc->GetActiveRenderData()->GetData(), NULL, NULL, CamImage, 0, NULL);
      ShowBitmap(CamImage);
        On 23/02/2005 at 01:42, xxxxxxxx wrote:
        Hm, just in case anyone cares..
        I've found a workaround (or maybe that's the way C4D handles rendering multiple frames? - I don't think so)
        I used the "BaseTime" parameters to get the frames I want and render them "by hand".
