Interdependent EditNumber Gadgets?
On 06/01/2005 at 01:26, xxxxxxxx wrote:
Cinema 4D Version: 8.012
Platform: Windows ;
Language(s) : C.O.F.F.E.E ; C++ ;---------
I have three EditNumber elements in a modal dialog. Two represent a frame range (i.e.: 0(min)-90(max)), and the other represents a step value (every nth frame).Initially, it is easy to set the limits. The step value is limited from 1 to max. But if the min or max is changed, I need to reset the step limit accordingly (so that it is not greater than max-min. I understand that I should use GeModalDialog::Message(), but how? As numbers are typed, the limit does not follow. What I really need to know is how to determine when entry is complete or follow it properly. I want these limits set while the dialog is opened, not after close.
Robert -
On 06/01/2005 at 07:41, xxxxxxxx wrote:
Oh, and that's supposed to be C++ only!
On 07/01/2005 at 11:33, xxxxxxxx wrote:
I found a solution, albeit rather ugly.
Since the only messages you get with the gadget ID are as the text is entered, CLEAR_FOCUS is used instead to call a method to check and correct all values according to these necessary limits - I can at least partially guarantee that entry is complete.
CheckValueRanges(), how do I put it, sucks. It works in just the way that I wouldn't want. I cannot use it and check the values on the way out of the dialog as well (with OK) - it either closes the dialog anyway (despite my and its protestations) or won't let it close at all. What use is this method? At least my method works both ways - interactively and during close.
Robert
