    Dialog Remove Items and refresh
    2 Posts 0 Posters 246 Views
      On 12/07/2004 at 15:49, xxxxxxxx wrote:
      Cinema 4D Version:   8.500
      Hi!
      I have a Dialog where I put some Items in on demand (textfields etc.)
      When this is done I call
      BaseContainer msg;
      msg.SetId(BFM_LAYOUT_CHANGED);
      SendParentMesssage(msg);
      This works fine and updates the dialog layout when calling it. BUT!
      When I want to remove these Elements by using RemoveElement() and then sending the Message to Parent this does NOT work - the Items are unavailable BUT the areas where thay are are not redrawn.
      Why? Does anyone of you hava an idea or better solution?
      Thank you,
      lawn
        On 12/07/2004 at 17:15, xxxxxxxx wrote:
        There is a better way, I think. See the AsyncTest.cpp file for how it handles dynamic (changing) groups. Then you can use this gem:
        void AsyncDialog::ReLayout(void)
             LayoutFlushGroup(GROUP_DYNAMIC);
             CreateDynamicGroup();
             LayoutChanged(GROUP_DYNAMIC);
        Now, this requires you to 'reconstruct', through your own CreateDynamicGroup() method, but it's fast enough to handle quite a large number of elements.
        HTH,
        Robert
