    i.d. stuff
    5 Posts 0 Posters 423 Views
      On 12/07/2004 at 13:08, xxxxxxxx wrote:
      Cinema 4D Version:   8.5
      I dont mean to be thick, but could someone please clarify a small point? I cant determine if an object is a SpherifyObject by using getclass( ), but the i.d. for one is 1001003.
         if ( obj->GetType()==1001003 )  println("a spherify object!");
      Is this a SAFE way to recognize an object , or do the i.d. s  ever change in different versions of cinema  ...
      cheers....
        On 13/07/2004 at 15:05, xxxxxxxx wrote:
        edit* I just noticed this is a coffee question. Sorry my response was for c++.
        Try doing it like this instead
        if(obj->GetType() == Osphere)
        Besides being safe between different versions of cinema, its much easier to read 🙂
          On 13/07/2004 at 16:33, xxxxxxxx wrote:
          Thanks anyway..........!
            On 13/07/2004 at 16:49, xxxxxxxx wrote:
            The IDs had better not change too often, or compiled C++ plugins would break. A prettier way, though no more dynamic, is to copy the enum or define from the C++ API to the top of your C.O.F.F.E.E. code. (I.e. so you could write Ospherify instead of 1001003.)
                const var Ospherify = 1001003;
              On 14/07/2004 at 06:44, xxxxxxxx wrote:
              Thanks for the help Mikael....
              I am a little paranoid at times!
