HyperNURBSObject prob
On 05/07/2004 at 01:57, xxxxxxxx wrote:
Cinema 4D Version: 8.5
Platform: Windows ;
Very annoying problem.
when I try to check if an object is a HyperNURBSObject, using GetType(), nothing happens, unless I use ID numbers instead..... e.g.
if (main_obj->GetType() == HyperNURBSObject ) println("hypernurbs");
The above does not work, but ...
println (main_obj->GetType() ) ; // gives the answer 1007455 for a hypernurbs object, SO...is the following CORRECT ?
if (main_obj->GetType() == 1007455 ) println("hypernurbs");
or is the number 1007455 also used for other objects????
please help, as my hair is falling out! -
On 05/07/2004 at 16:23, xxxxxxxx wrote:
Ahhh! It`s ok.
I have found another way of doing what I am after......... -
On 07/07/2004 at 20:27, xxxxxxxx wrote:
Just for the record, obj->GetType() returns the integer ID while getclass(obj) would return the actual class (HyperNURBSObject).
On 09/07/2004 at 01:21, xxxxxxxx wrote:
Thanks a lot for the info, (I`ve been offline for a few days).....
