TagData: Dynamically creating AM?
On 13/04/2004 at 05:42, xxxxxxxx wrote:
Cinema 4D Version: 8.206
Language(s) : C++ ;---------
I have an idea for a TagData plugin and it envolves dynamically creating controls for the AM.
I need to AM to be completely generated through code. With a dialog plugin, its easy because I have access to CreateLayout, but there doesnt seem to be a tagdata equivalent.
Is this even possible? -
On 13/04/2004 at 15:37, xxxxxxxx wrote:
See NodeData::GetDDescription(). (Note that you'll still get the same layout limitations as with a description resource file, i.e. it won't be the same as CreateLayout().)
On 05/06/2004 at 14:40, xxxxxxxx wrote:
Bringing alive old thread, but its revelant.
For the life of me I can't dynamically add widgets into a AM field.
This is my code, almost an cut andpaste from the forumBool MyTagPlugin::GetDDescription(GeListNode *node, Description *description, LONG &flags) { LONG dtype = DA_LONG; BaseContainer descbc = GetCustomDataTypeDefault(dtype); String name = "my param name"; descbc.SetString(DESC_NAME, name); descbc.SetString(DESC_SHORT_NAME, name); // etc for DESC_MIN, DESC_MAX, DESC_MINSLIDER, DESC_MAXSLIDER descbc.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_LONGSLIDER); DescID descid(DescLevel(33333, dtype, MY_PLUGIN_ID)); if (!description->SetParameter(descid, descbc, DescLevel(ID_TAGPROPERTIES))) return false; flags |= DESCFLAGS_DESC_LOADED; return TagData::GetDDescription(node,description,flags); }
When I look at my AM, it is just completely blank.
Why? -
On 08/06/2004 at 04:38, xxxxxxxx wrote:
You have to add
if (!description->LoadDescription(node->GetType())) return FALSE;
as the first line of the function. The reason is that otherwise the basic Tbase description isn't loaded, and without it ID_TAGPROPERTIES isn't a valid groupid.
