MatAssignData
On 31/03/2004 at 08:04, xxxxxxxx wrote:
Cinema 4D Version: 8.207
Platform: Windows ;
Language(s) : C++ ;---------My MaterialData needs to know to which objects its assigned to. The MatAssignData class is documented in the sdk....but how can I get a pointer to it from my MaterialData???
On 01/04/2004 at 01:34, xxxxxxxx wrote:
MatAssignData* test = (MatAssignData* ) bcMat.GetCustomDataType( ID_MATERIALASSIGNMENTS, CUSTOMDATATYPE_MATASSIGN );
......ok....but now I need to call test->BuildInclusionTablem which returns a MatAssignTable...but MatAssignTable* leads to a linker error.......
On 06/04/2004 at 01:59, xxxxxxxx wrote:
What linker error? Which compiler/linker?
On 18/11/2004 at 18:41, xxxxxxxx wrote:
I have the same problem.
When I try to build my plugin the compiler tells me:
error LNK2001: unresolved external symbol "public: class MatAssignTable * __thiscall MatAssignData::BuildInclusionTable(class BaseDocument *,long)" (?BuildInclusionTable@MatAssignData@@QAEPAVMatAssignTable@@PAVBaseDocument@@J@Z)
fatal error LNK1120: 1 unresolved externalsI don´t know why. I have included the customgui_matassign.h and my code is correct too (it compiles without problems)
Any idea what the problem may be?
Thanks!
On 01/12/2004 at 03:14, xxxxxxxx wrote:
Hmm, no. It seems to work here. What compiler do you use?
On 01/12/2004 at 07:44, xxxxxxxx wrote:
MSVC++ 6. It just doesn´t work.
On 02/12/2004 at 00:55, xxxxxxxx wrote:
I never got BuildInclusionTable to run, I use the ObjectFromIndex function to get access to the assign data.
On 23/05/2007 at 17:29, xxxxxxxx wrote:
Hey Guys,
I need to access all of the elements found within the Assignment page of a given material. Now, I found the matAssignData class which is exactly what I am looking for. The problem is that when ever I call the GetTheCustomDataType() it ALWAYS returns NULL! Here is the code:if(!replaceMaterial || !withMaterial) return TRUE; BaseContainer *rmBC = replaceMaterial->GetDataInstance(); MatAssignData *replaceAssignData = (MatAssignData* )rmBC->GetCustomDataType(ID_MATERIALASSIGNMENTS, CUSTOMDATATYPE_MATASSIGN); if(!replaceAssignData) { GePrint("MatAssignData is NULL!"); return TRUE; }As always thanks in advance for any help.
-Josh- -
On 24/05/2007 at 02:49, xxxxxxxx wrote:
Here a little example how to access the MatAssigData.
BaseMaterial *mat = doc->GetActiveMaterial(); if(!mat) return TRUE; GeData d; if(mat->GetParameter(DescLevel(ID_MATERIALASSIGNMENTS),d,0)) { MatAssignData *mad = (MatAssignData* )d.GetCustomDataType(CUSTOMDATATYPE_MATASSIGN); if(mad) GePrint("found it"); GePrint(LongToString(mad->GetObjectCount())+" objects"); }hope this helps
Matthias -
On 24/05/2007 at 02:57, xxxxxxxx wrote:
Yes that should work, is also the way we use it.
Be careful, every time you make the get on it, the assign list of the material will be updated. We noticed that this takes a longer while if the material is assigned to many objects. Seems to me, that the assign list itself has a non optimal implementation, like if adding an entry to the list takes O(n²), n the number of entries which are already in the list. It does not seem to depend on the size of the object tree, that has to be parsed for filling the assign list, but that seems to be fast, a material used only in several objects but with a very huge object tree is still fast. -
On 24/05/2007 at 08:29, xxxxxxxx wrote:
Thanks Matthias! It worked like a charm;
-Josh-
