    Sound question
    4 Posts 0 Posters 549 Views
      On 19/11/2003 at 07:39, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Is it possible to get a sound that is put in an animation, or it's frequency?
      If so, how would I go about doing this?
      Thank you
        On 21/11/2003 at 08:13, xxxxxxxx wrote:
        Take a look at the class "BaseSound".
        Also you can use XPresso to control animation.
          On 02/06/2005 at 06:33, xxxxxxxx wrote:
          i´m trying to use xpresso to control animation trought soud intensity but i don´t find a way to connect the soundlevel output wit a user data input 😞
            On 27/10/2005 at 15:14, xxxxxxxx wrote:
            hi antz,
            are you still hunting that rabbit 😄
            like beaker said the sound class is the right one. all you need is to load the sound file and divide samplecount/soundlength and keep the frame rate in mind. then you can loop through the samples per frame..
            i would sudjest to do that within xpresso (coffee node). the better place seems to be the c++ sdk though.
