    Compiling my plugin on R23
    Cinema 4D SDK
    1.1k
    • P
      pim
      I compiled my plugin for R23 on a PC and no problems.
      Now I want to do the same on the Mac (10.15.6) using Xcode 11.3.1.
      I copied the sdk and the ran R23 projecttool to /Documents.
      Everything seems ok, plugins.xcode was created and looks good.
      Again, I am doing everything in my Documents folder, so I should not have any protection / privilege issues.
      But I get the following IOError.
      projectdefinition.txt
      • P
        pim @pim
        Even compiling everything from default (microsdk) gave an error:
        error: Build input file cannot be found:
        '/Users/pgrooff/Documents/R23_sdk/sdk_R23.008/frameworks/core.framework/generated/hxx/register.cpp' (in target 'core.framework' from project 'core.framework')
        I downloaded and installed everything from scratch.
        I am using Mac 10.15.6 and Xcode 11.3.1.
        • P
          pim
          Here the folder structure.
          • P
            pim
            After
            "The default interactive shell is now zsh.
            To update your account to use zsh, please run chsh -s /bin/zsh."
            I started Xcode, did a "Clean Build Folder" and compiled again.
            • Error
            • Compiled again
            • Error
            • Compiled again
            Success!
            So, I had to do a lot of compiles, before I had success.
            I guess the hxx files were not generated yet.
            I will now try my own plugin.
            • P
              pim
              I now changed projectdefinition.txt to compile my own plugin, but i keep getting
              File "/Users/pgrooff/Documents/R23_sdk/sdk_R23.008/frameworks/settings/sourceprocessor/declarations.py", line 123, in writeToFile
              f = open(file, 'w')
              IOError: [Errno 1] Operation not permitted: '/Users/pgrooff/Documents/R23_sdk/sdk_R23.008/plugins/getloglines/generated/sourceprocessor.stamp'
              Command PhaseScriptExecution failed with a nonzero exit code
              Is the sequence of building correct?
              • P
                pim
                Ok, success.
                Copying the plugin folder from pc to mac was the issue!
