    Downward compatibility...etc...
    2 Posts 0 Posters 332 Views
      On 11/08/2003 at 04:18, xxxxxxxx wrote:
      Cinema 4D Version:   8.100
      Language(s) :   C.O.F.F.E.E  ;  C++  ;
      Q:
      1. Working with Visual C++ is there a easy way to secure downward compatibility to C4D 6.3 ???
      2. Which Plugins are faster/more efficient : C++ or Coffee Plugins - and where do I get a compiler for Coffee ??? And what is it with Expressions ? They are only interpreted and slow, right ?
      3. Sorry, for this question (I will read soon more when I finished the priorities) but, can somebody give me an impression about Xpresso ? Is it a real alternative to C++ plugins ? Is it just interpreted (slow) or compiled (fast)...etc...
      4. Even after convertying the sdk/api files from Unix to Dos format I can't successfully compile the sdk plugin examples with C++ - there is still one bug. I don't know what the line is doing, but I commeted it out and now it works - but still I have a bad feeling. Will there soon (when ???) be a new C4D point release fixing this problem ??? How much energy does Maxon use to care for the Plugin Development - because it still looks slightly buggy and not optimal documented...I still haven't found a hook to get into it, despite the fact, I know C4D very well...
      jago
        There is no backward compatibility. you need to recompile your plugins with earlier API versions if you want backward compatibility. But there is most of the time forward compatibility.
        C++
        you can write COFFEE plugins in a normal texteditor (i.e. windows notepad). Actually COFFEE plugins don´t need any compilation to work. And they are plattform independent and most of the COFFEE code can easily be reloaded directly in Cinema 4D without the need to close/reopen Cinema 4D.
        A compiler though is available here in the Plugincafe. Please see the online COFFEE documentation. There is a link to the compiler.cof file (it´s a coffee file).
        They are used as expressions directly in Cinema 4D. They can be pretty fast, depending on the task. But it´s not possible to have "plugins" with COFFEE expressions.
        Xpresso is a node based animation! system that interacts with the scenery in Cinema 4D. It´s not possible to write plugins with it. There is no code. It´s no alternative to C++ or COFFEE if you want to write plugins. Please see the Cinema 4D documentation for more information on Xpresso.
        Sorry I cannot confirm. The SDK is very well documented. Some areas are a bit buggy but nothing earth moving. The complete SDK support is done here in the plugincafe by Mikael Sterner and David O´Reilly.
        To your line. Cannot help you if I don´t know the line you are refering to. And probably Mikael is the better guy to answer those kind of questions I guess.
        HTH
        Samir
