    Calculate the rounding radius max value of a n-Side object
    c++sdk
    3 Posts 2 Posters 962 Views 1 Watching
    • mfersaouiM Offline
      mfersaoui
      I'm searching how to calculate the rounding radius maximum value of a n-Side object.
      I tried with the following but it doesn't work:
      Float calculateSide(Int32 n, Float r)
      	Float theta, theta_in_radians;
      	theta = 360 / n;
      	theta_in_radians = theta * 3.14 / 180;
      	return 2 * r * sin(theta_in_radians / 2);
      Float	max_rrad = calculateSide(n, r)/2;
      • CairynC Offline
        Cairyn
        Assuming you mean a regular polygon, the maximum rounding radius is the same as the incircle of the polygon (as at this point all roundings touch and form a circle).
        For formulas, see e.g.
        https://www.mathopenref.com/polygonincircle.html
        mfersaouiM 1 Reply Last reply Reply Quote 1
          mfersaoui @Cairyn
          @Cairyn
          Thank you.
          Solution:
          Float GeIncircle(Int32 n, Float r)
          	return r * cos(PI / n);
          Float	max_rrad = GeIncircle(n, r);
