    Retrieving Deformed Splines
    c++r20sdk
    3 Posts 2 Posters 890 Views 2 Watching
    • J Offline
      JohnThomas
      I'm trying to get access to the result of a spline that has been deformed by a Bend. I've attached a scene file with a cloner mimicking the behavior I want to achieve, but I haven't been able to do it yet.
      Using GetCache().GetDeformCache() isn't returning just the four points of the circle and I'm not sure another way to get a deformed spline. This seems like it would be rather simple but I'm not sure where to proceed.
      Deformed Circle.c4d
      Johan
      • r_giganteR Offline
        r_gigante
        Hi Johan, thanks for reaching out us.
        With regard to your request, I warmly suggest to have a look at:
        • c4d.utils.SplineHelp
          • SplineHelp.SplineToLineIndex() to find a correspondence between spline points and their sibling in the cache representation
        • BaseObject.GetCache() to see how to properly retrieve a geometry cache
        • BaseObject.GetRealSpline() to retrieve a real spline from a spline generator
        A first attempt to make it work should look like this:
        def DoRecursion(op, index):
            tp = op.GetDeformCache()
            if tp is not None:
                DoRecursion(tp, index)
                tp = op.GetCache()
                if tp is not None:
                    if not op.GetBit(c4d.BIT_CONTROLOBJECT):
                        if op.IsInstanceOf(c4d.Opoint):
                            for i in index:
                                print "\t\t", op.GetAllPoints()[i]
            tp = op.GetDown()
            while tp is not None:
                tp = tp.GetNext()
        # Main function
            # get the real spline representation
            realSpline = op.GetRealSpline()
            if realSpline is None:
            # allocate a SplineHelp instance and init it with the real spline
            splineH = c4d.utils.SplineHelp()
            splineH.InitSplineWith(realSpline)
            # get the spline points and store its length
            splinePnts = realSpline.GetAllPoints()
            splinePntsCnt = len(splinePnts)
            # allocate a list to store the correspondance between the spline points and the one belonging to its line representation
            pntIndxInLine = []
            for i in xrange(splinePntsCnt):
                pntIndxInLine.append(splineH.GetPointIndex(i, 0)/splinePntsCnt)
            # recurse over the geometry to look for its cache
            DoRecursion(op, pntIndxInLine)
            # free the SplineHelp instance
            splineH.FreeSpline()
        # Execute main()
        Best, Riccardo
        • J Offline
          JohnThomas
          Thanks for the reply, it really helped me out.
          John
