Creating poly selections for texture map
On 24/05/2003 at 22:38, xxxxxxxx wrote:
Cinema 4D Version: 8.100
Platform: Windows ;
Language(s) : C++ ;---------
How can I create polygon selections to use with multiple materials on polygon objects? I get an instant crash trying to create a Tpolygon tag on a polygon object and the Tpolygonselection tag has no accessors that would let me set which polys are part of the set. No examples for these guys. I need two sets of groupings - one for surfaces to apply uv based textures to - and one denoting groups that I will be using to create bone weight maps later.How can I divide up the model I've imported so I can properly texture it from within my plugin?
(where I can find samples, the sdk has gotten me up and running very fast!)
David -
On 25/05/2003 at 01:12, xxxxxxxx wrote:
Use SelectionTag::Alloc(Tpolygonselection) and then GetBaseSelect() to modify the selection. I think you need to call tag->Message(MSG_UPDATE) if you change anything.
You cannot create Tpolygon since there can only be one such tag. It shouldn't crash, but perhaps you don't check for NULL pointers? -
On 25/05/2003 at 08:45, xxxxxxxx wrote:
Thanks!
Once I knew what to go for - works like a charm.How do you know which tags should be created by the calls in baseobject - should I use MakeVariableTag for a Tvertexmap for a bone weight map and it must be the size of the entire point array? Or is there a way to make a sparse array (like selection appears to be) for bone weights?
(Finally on to textures!)
David -
On 25/05/2003 at 08:46, xxxxxxxx wrote:
Thanks!
Inever got to check the null Tpolygon pointer - it never returned- I was using object->MakeVariableTag.
David
