    Rotate selected polygons
    r20pythonwindows
    3 Posts 2 Posters 882 Views 1 Watching
    • P Offline
      pim
      How can I rotate just the selected polygons (or points) of an object?
      Edit:
      I solved it for points, so polygons should be possible too.
      from c4d import gui
      def rot_points(obj, new_axis):
        mat = ~new_axis * obj.GetMl()
        if obj.CheckType(c4d.Opoint):
          points = obj.GetAllPoints()
          bs = op.GetPointS()
          sel = bs.GetAll(op.GetPointCount())
          for index, selected in enumerate(sel):
            if not selected:
              pass
              points[index] = points[index] * mat
          obj.SetAllPoints(points)
          obj.Message(c4d.MSG_UPDATE)
      # Main function
      def main()
          mat = op.GetMl() * c4d.utils.MatrixRotX(c4d.utils.Rad(45))
          rot_points(op, mat)
      # Execute main()
      • a_blockA Offline
        a_block
        Hi Pim,
        although you marked this already as solved, I'd just like to clarify one point.
        There is no such thing as rotating polygons. Polygons are just made up of points (or rather point indexes), with the edges being implicitly defined by the order of points in a CPolygon. So rotating a polygon boils down to rotating the points involved in this polygon.
        Andreas
        • P Offline
          pim
          Hi Andreas,
          Ok, so I have to rotate the points to rotate a polygon.
          I thought so. That is why I assumed that when I can rotate points, I can rotate polygons.
          Thanks.
          Regards, Pim
