    General question [SOLVED]
    ResEdit
    0
    1.3k
    • H
      On 19/04/2003 at 12:26, xxxxxxxx wrote:
      ResEdit Version:   R8
      I use a lot the ReEdit, but it some case I get Error in it when I open
      The typical exemple is the Color C4D object
      To show all stuff in it, I have to say OEPN , ok ois save and work fine
      But when I ReOpen the Dialog in the reEdit it show an error , I have to go in the code to remove the OPEN;
      Also I try to use HTe links Object and try to make some change
      TO acpet or exclude stuff in it. There aloso is a problem.
      Just for you to Know I use all that in a standard GeDialog overLoad Class
      Niki
      • H
        On 20/04/2003 at 01:47, xxxxxxxx wrote:
        Hi
        This was a bug. Thanks. You may use the normal color chooser (instead of the custom GUI).
        Currently you can't change the accepted / refused objects in ResEdit. You can modify the accepted objects in your dialog GeDialog::Command function. The container elements are:
            #define LINKBOX_ACCEPT_MESSAGE_TYPE         1       // LONG  - the type of the item dragged in the link box
            #define LINKBOX_ACCEPT_MESSAGE_ELEMENT      2       // a pointer (BaseList2D* ) to the object cast to LONG
            #define LINKBOX_ACCEPT_MESSAGE_ACCEPT       3       // a pointer to a Bool, cast to long (set this value to TRUE, if you want to accept the object)
            #define LINKBOX_ACCEPT_MESSAGE_CONTROL_ID   4       // the ID of the control that sent the message
        • H
          On 20/04/2003 at 04:20, xxxxxxxx wrote:
          It start to come 🙂
          Bit I thinks I Miss one part there... I'm New in thois SDK, I know C++ but not much the C4D SDK.
          So at the base in the dialog I set it that way
          class AmaToolsDialog : public GeDialog
               private:
                    Filename MatFileToScan;
                    bool ValidePoserFile;
                    BaseLink *FigureLink;
                    BaseLink *MatToCopyLink;
                    BaseLink *MatMatToolsLink;
          LONG count;
          but now in the GeDialog::command
          I never see those LINKBOX_ACCEPT_MESSAGE_TYPE, etc...
          I look in your code an I see a "LinkBoxGui" where it show those messages etc...
          But how to Construct this LinkBoxGui ?
          any it work now, but can test the Accept etc. and also can't show the Link when I reopen my dialog 😞
          Well is not that important, so take your time and pass good Holidays
          Niki
          • H
            On 20/04/2003 at 08:07, xxxxxxxx wrote:
            Hi Niki
            Your Message function should be called as soon as the user drags an item over the link box. Sorry, I was wrong in my previous post. It's the message function. The Container ID is MSG_DESCRIPTION_CHECKDRAGANDDROP.
            I have just tested and it works:
                LONG YourDialogClass::Message(const BaseContainer &msg, BaseContainer &result)
                  if (msg.GetId() == MSG_DESCRIPTION_CHECKDRAGANDDROP)
                    LONG item_type = msg.GetLong(LINKBOX_ACCEPT_MESSAGE_TYPE);
                    BaseList2D* obj = (BaseList2D* )msg.GetLong(LINKBOX_ACCEPT_MESSAGE_ELEMENT);
                    Bool *accept = (Bool* )msg.GetLong(LINKBOX_ACCEPT_MESSAGE_ACCEPT);
                    LONG linkbox_id = msg.GetLong(LINKBOX_ACCEPT_MESSAGE_CONTROL_ID);
                    // set *accept TRUE, if the object should be accepted, FALSE otherwise.
                  return SubDialog::Message(msg, result);
            You don't need to construct it. It's done when the dialog is created. You can find the pointer with GeDialog::FindCustomGui.
            Use LinkBoxGui::SetLink in InitValues.
            Happy Coding :-))
            • H
              On 20/04/2003 at 09:30, xxxxxxxx wrote:
              Thanks You verry much ! It work Now 🙂
                        //LONG item_type = msg.GetLong(LINKBOX_ACCEPT_MESSAGE_TYPE);
                        if(linkbox_id == IDC_FIGURE_LINK) {
                             if(!obj->IsInstanceOf(Opolygon))
                                  *accept = false;
                        if((linkbox_id == IDC_MATTOCOPY) || (linkbox_id == IDC_MATTOOL_MATLINK)) {
                             if(!obj->IsInstanceOf(Ttexture) && !obj->IsInstanceOf(Mmaterial))
                                  *accept = false;
              return GeDialog::Message(msg,result);
              I will have others stupid questions but I let you pass the holidays now...
              Niki
