    Change filter of the one view
    5 Posts 0 Posters 988 Views
      On 13/03/2018 at 07:25, xxxxxxxx wrote:
      I'm trying to change a grid filter that only the perspective view.
      I was predictable, my code doesn't work.
      The following code changes grid filter for all viewport.
          bd = doc.GetActiveBaseDraw()
          drawFilter = bd.GetDisplayFilter()
          cam = bd.GetEditorCamera()
          projection = cam.GetProjection()
          if projection == c4d.Pperspective:
              if drawFilter & c4d.DISPLAYFILTER_GRID:
                  bd[c4d.BASEDRAW_DISPLAYFILTER_GRID] = False
                  bd[c4d.BASEDRAW_DISPLAYFILTER_GRID] = True
          bd.Message(c4d.MSG_CHANGE)
      Could I change grid filter for one of a view or only perspective view?
      If it possible, where can I get this information in the SDK?
        On 14/03/2018 at 06:04, xxxxxxxx wrote:
        I'm afraid you've hit a limitation. It's not possible to change the filter for only one view.
        The display filter is synchronized for all views and the API doesn't allow to circumvent this limitation.
          On 14/03/2018 at 06:37, xxxxxxxx wrote:
          Hi Yannick,
          Thank you tell me this information👍
          Makoto
            On 14/03/2018 at 09:57, xxxxxxxx wrote:
            In fact it's possible to change the filter for a specific view via the UI with the following steps:
            Options->Configure->Filter->Right-click on a parameter->Make Parameter Local
            Unfortunately there's no way to do this with the API.
            See the Cinema 4D documentation here.
              On 16/03/2018 at 04:43, xxxxxxxx wrote:
              Hi Yannick,
              Thanks to you I was able to make small scripts.
              Thank you!!
              Cheers🍺
              Makoto
