    Easing script
    3 Posts 0 Posters 657 Views
      On 11/02/2018 at 05:37, xxxxxxxx wrote:
      Hi everybody, I'm trying to add an ease-in expression to a rig. I'm not really a math guy, so I'm referencing Penner's equation and in particular this doc: http://upshots.org/actionscript/jsas-understanding-easing.
      My code for testing looks like this so far:
      import c4d, math
      start = 10   #start pos
      end = 300    #end pos
      d = 50       #duration
      def easein(t,d) :
          ratio = t/d
          print "ratio: ",ratio
          return math.pow(ratio,5)
          t = doc.GetTime().GetFrame(doc.GetFps()) #current frame
          factor = easein(t,d)
          out_pos = start + (end-start) * factor
          print "t: ", t
          print "d: ", d
          print "factor: ", factor
          print "out pos: ", out_pos
      but the result of (t/d) is always 0.0. I guess is something with the values type but I can't figure it out.
      What am I doing wrong?
      Thanks for any advice or help!
      cheers
      massimiliano
        On 12/02/2018 at 01:49, xxxxxxxx wrote:
        you are calculating the ratio as an integer division. Simple solution, either make d a float value (d = 50.0) or force the division to be calculated with floating point (ration = float(t) / float(d)).
        Here's some information on Floating Point Arithmetic in the Python docs.
        Please also note, Cinema 4D use a 2.7.x implementation of Python. There is a change in behavior of integer division compared to Python 3.x, see for example here.
          On 12/02/2018 at 12:21, xxxxxxxx wrote:
          Ahh, that makes sense. Thanks for the help!
          Massimiliano
