    Hide attributes
    3 Posts 0 Posters 690 Views
      On 01/01/2018 at 08:11, xxxxxxxx wrote:
      is it possible to alter already existed description?
      I have an object generator plugin that has 2 attributes. Slider and CheckBox.
      Currently, I'm only ghosting the slider by using CheckBox But I want to completely hide it.
      TESTPLUGIN_ID = 1000001 #Temporary ID
      TESTPLUGIN_VALUE = 10000 #Real Slider
      TESTPLUGIN_BOOL = 10001 #Bool CheckBox
      class Testplugin(c4d.plugins.ObjectData) :
          def Init(self, node) :
              self.InitAttr(node, float, TESTPLUGIN_VALUE)
              node[TESTPLUGIN_VALUE] = 0
              self.InitAttr(node, bool, TESTPLUGIN_BOOL)
              node[TESTPLUGIN_BOOL] = True
          def GetDEnabling(self, node, id, t_data, flags, itemdesc) :
              if id[0].id == TESTPLUGIN_VALUE: return bool(node[c4d.TESTPLUGIN_BOOL])
        On 01/01/2018 at 11:57, xxxxxxxx wrote:
        You will need to use the DESC_HIDE in GetDDescription(), gr4ph0s already provided a link to such discussion:
        https://developers.maxon.net/forum/topic/9824/13229_hide-descelements-r18
        Have a look at the last post in above discussion
          On 01/01/2018 at 19:57, xxxxxxxx wrote:
          Sorry, I somehow missed this answer by gr4ph0s
          It helped.
          I'll upload this plugin here.
          https://www.dropbox.com/s/ryq9r41qnvnbpnt/Test Plugin1.zip?dl=0
