    Vertex map is not correctly filled
    2 Posts 0 Posters 581 Views
      On 18/12/2017 at 11:40, xxxxxxxx wrote:
      I have an objectdata plugin.
      In GetVirtualObjects() I create a vertex map.
      This vertex map is the then used in a Smoothing deformer.
      The hierarchy is then:
      - Null
        Smoothing deformer
        objA - vertex deformer.
      This works! Smoothing is visible.
      I can see that if I insert a clone of this intermediate result.
      After that I do a CSTO, but then it seems as if the vertex map is not correctly filled.
      No smoothing is visible.
          def GetVirtualObjects(self, op, hierarchyhelp) :
              doc = op.GetDocument()
              if op.GetDown() is None or op.GetDown().GetNext() is None:
                  return c4d.BaseObject(c4d.Onull)
              res = op.GetAndCheckHierarchyClone(hierarchyhelp, op.GetDown(), c4d.HIERARCHYCLONEFLAGS_ASPOLY , True)
              if res['dirty'] == False:
                  return res['clone']
              objA = res['clone'].GetDown()
              objB = objA.GetNext()
              vertexMap = self.Selection2VertexMap(objA)  #create and add vertex map. This works.
              null2 = c4d.BaseObject(c4d.Onull)
              objA.InsertUnder(null2)
              smoothingObject = c4d.BaseObject(1024529)     #smoothing
              smoothingObject[c4d.ID_CA_SMOOTHING_DEFORMER_OBJECT_STRENGTH] = .20
              smoothingObject[c4d.ID_CA_SMOOTHING_DEFORMER_OBJECT_ITERATIONS] = 20
              smoothingObject[c4d.ID_CA_SMOOTHING_DEFORMER_OBJECT_STIFFNESS] = 1.0
              smoothingObject[c4d.ID_CA_SMOOTHING_DEFORMER_OBJECT_STIFF_MAP] = vertexMap
              smoothingObject.InsertUnder(null2)
              cstoObject = self.CSTO(doc, null2)
              doc.InsertObject(null2.GetClone())          #debug: Show intermediate result
              return cstoObject
        On 18/12/2017 at 13:08, xxxxxxxx wrote:
        I guess I solved it.
        I am now using a temp document for the csto.
