    Arrange UI Elements
    3 Posts 0 Posters 492 Views
      On 19/07/2017 at 08:15, xxxxxxxx wrote:
      I'm quite new to python for c4d, so it might be newbie question.
      Does anyone know how to organize elements so that they are arragend next to each other instead of top/down?
      this is my current class
      class MainMenu(gui.GeDialog) :
          def CreateLayout(self) :
              template_fn = next(os.walk(path))[2]
              template_filecnt = len(template_fn)
              #print template_fn
              #print template_filecnt
              bc = c4d.BaseContainer()    #Create a new container to store the button image
              buttid = 1000               #start id for 1000
              i=0                         #set iterator
              for list in template_fn:
                  #create buttons
                  template_path = os.path.normpath(os.path.join(dir,'res/templates/',template_fn[i]))   #The path to the image
                  bc.SetFilename(buttid, template_path)                                  #Add this location info to the conatiner
                  self.myBitButton=self.AddCustomGui(buttid, c4d.CUSTOMGUI_BITMAPBUTTON, "Bitmap Button", c4d.BFH_CENTER, 30, 30, bc)
                  self.myBitButton.SetImage(template_path, False)                                  #Add the image to the button
                  #button id counter, gives every button unique id, i = loop counter for iteration through list
                  buttid+=1
                  i+=1
          def Command(self, id, msg=None) :
              print id
        On 19/07/2017 at 08:56, xxxxxxxx wrote:
        I suggest you to read https://developers.maxon.net/docs/cpp/2023_2/page_manual_gedialog.html you gonna learn alot about dialog inside c4d.
        According your ask take basicly you have to make a group to arrange them.
        So it's looks like this
        class MainMenu(c4d.gui.GeDialog) :
                count = 10
                id_group = 10001
                base_id_text = 10002
                #important to set columns number
                if self.GroupBegin(id_group, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, cols=count) :
                    #Add content to our group
                    for i in xrange(count) :
                        self.AddStaticText(base_id_text + i, c4d.BFH_SCALEFIT, name="text_{}".format(str(i)))
                self.GroupEnd()
            win = MainMenu()
            win.Open(c4d.DLG_TYPE_MODAL_RESIZEABLE)
          On 20/07/2017 at 00:28, xxxxxxxx wrote:
          Thanks, it works like a charm!
          and thanks for the cpp manual link it gives lots more info then the python one.
