    Constraint tag properties
    11 Posts 0 Posters 1.6k Views
      On 07/04/2017 at 06:11, xxxxxxxx wrote:
      All help is appreciated!
      I am stuck at the moment.
      -Pim
        On 07/04/2017 at 06:56, xxxxxxxx wrote:
        I don't have a c++ environnent atm.
        But here a python code which work and where you could easily port it into C++
            tag = doc.GetActiveTag()
            #useless but c++ code style
            bc = c4d.BaseContainer()
            #Get the bc
            bc = tag.GetParameter(c4d.DescID(50004), c4d.DESCFLAGS_GET_0)
            #Change the value to 2 => Z+
            #Not sure it's a long maybe Int32 Don't know but oyu get the idea
            bc.SetLong(3, c4d.ID_CA_CONSTRAINT_TAG_AXIS_ZP)
            #Reassign the bc
            tag.SetParameter(c4d.DescID(50004), bc, c4d.DESCFLAGS_SET_0)
        After maybe there is a more efficiency method to do it. But I guess this one will work.
        Hope it's help.
          On 07/04/2017 at 09:12, xxxxxxxx wrote:
          Hi Pim,
          sorry for letting you wait. Unfortunately I'm not done with your case, yet, but I don't want to leave you without any answer before the weekend.
          In general your code seems to be working here. The thing is, while running in debugger, it's internally running on a bunch of CriticalStop(), which I haven't found the reason for, yet. Neither a workaround. These critical stops might look to you as if C4D has crashed, while it actually has not and you can simply press "continue" in your debugger. So if I use your code in a CommandData and step over the CriticalStops then the outcome looks actually fine to me.
          So, I'm wondering, what is your actual issue. Is it the critical stops? I will investigate more in this direction Monday. But maybe you are having different issues, I have overlooked so far. In that case, please provide me with some more details.
            On 07/04/2017 at 09:18, xxxxxxxx wrote:
            Hi Andreas,
            I do not get a crash of some sort.
            The parameter is just not set.
            I will gr4ph0s solution.
            -Pim
              On 07/04/2017 at 09:20, xxxxxxxx wrote:
              Hm, that part seems to work nicely here. Maybe you are just lacking the EventAdd() in the end? Or other question I forgot to ask, in which context are you using the posted code? Is it in a CommandData or somewhere else?
                On 07/04/2017 at 09:42, xxxxxxxx wrote:
                Yes, I am using a commanddata.
                And I was wrong, cinema indeed seems to crash but I can continue, but the parameters are not set.
                And yes, I use an EventAdd() at the end.
                I will do some test.
                  On 07/04/2017 at 09:56, xxxxxxxx wrote:
                  Running outside the debugger does gives no crashes, but not all parameters are not set.
                  Tag name set.
                  Clamp is set.
                  Target is set.
                  ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE not set.
                  ID_CA_CONSTRAINT_TAG_AXIS_ZP not set.
                  Phong Normals not set.
                  constraintTag->SetName("C4Dome RL");
                  res = constraintTag->SetParameter(ID_CA_CONSTRAINT_TAG_CLAMP, TRUE, DESCFLAGS_SET_0);
                  res = constraintTag->SetParameter(50001, surfaceObject, DESCFLAGS_SET_0);			//set target
                  res = constraintTag->SetParameter(DescID(50004, 1), ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE, DESCFLAGS_SET_0);
                  res = constraintTag->SetParameter(DescID(50004, 3), ID_CA_CONSTRAINT_TAG_AXIS_ZP, DESCFLAGS_SET_0);				//set align = +z
                  res = constraintTag->SetParameter(DescID(50004, 4), 2, DESCFLAGS_SET_0);
                    On 07/04/2017 at 10:14, xxxxxxxx wrote:
                    Hi gr4ph0s,
                    I cannot get your solution to work.
                    The compiler complains or cinema hangs (in de code below).
                    //Get the bc
                    BaseContainer* bc;
                    GeData d;
                    res = constraintTag->GetParameter(DescID(50004), d, DESCFLAGS_GET_0);
                    bc = d.GetContainer();
                    bc->SetInt32(1, ID_CA_CONSTRAINT_TAG_CLAMP_TO_SURFACE);
                    //Reassign the bc
                    d.SetContainer(*bc);
                    constraintTag->SetParameter(DescID(50004), d, DESCFLAGS_SET_0);
                      On 07/04/2017 at 11:37, xxxxxxxx wrote:
                      #include "c4d.h"
                      #include "c4d_symbols.h"
                      #include "tcaconstraint.h"
                      #include "main.h"
                      #define ID_SWITCH_CONSTRAINT_TOOL 10000010
                      class SwitchConstCommand : public CommandData
                      	Bool Execute(BaseDocument* doc)
                              if (!doc)
                                  return false;
                              BaseTag* tag = doc->GetActiveTag();
                              if (tag == nullptr)
                                  return false;
                              if (tag->GetType() != 1019364)
                                  return false;
                              BaseContainer* bc_tag = tag->GetDataInstance();
                              BaseContainer* bc_clamp = bc_tag->GetContainerInstance(50004);
                              bc_clamp->SetInt32(3, ID_CA_CONSTRAINT_TAG_AXIS_ZP);
                              EventAdd();
                      	return true;
                      Bool RegisterSwitchConst()
                          return RegisterCommandPlugin(ID_SWITCH_CONSTRAINT_TOOL, nullptr, 0, nullptr, String(), NewObjClear(SwitchConstCommand));
                      Worked here. But I just start to learn C++ and the c++ sdk so they might have a better solution for doing this kind of stuff using directly SetParameter.
                        On 07/04/2017 at 12:49, xxxxxxxx wrote:
                        Thanks, it works.
                        I forgot to get the first container.
                        -Pim
