    fusion shader insert shader()
    3 Posts 0 Posters 433 Views
      On 06/03/2017 at 08:08, xxxxxxxx wrote:
      I am having problems filling both channels of the fusion shader with python.
      What I am trying to achieve is:
      - Take the existing shader, if any, from the colour channel.
      - Create a fusion shader
      - Insert a colour shader in the blend channel
      - Insert the original shader in the base channel
      - Insert the fusion shader into the colour channel
      I can add the colour shader & update the material with the fusion shader but when I try to add the original shader to the base channel I get the message:
      "AssertionError: Found next objects. Please add them seperately"
      I guess it is a syntax problem.
      Here is a synapsis of my code:
      existing_shader = mat[c4d.MATERIAL_COLOR_SHADER]
      col_shader = c4d.BaseList2D(c4d.Xcolor)
      fusion_shader = c4d.BaseList2D(c4d.Xfusion)
      fusion_shader[c4d.SLA_FUSION_BLEND_CHANNEL] = col_shader
      fusion_shader.InsertShader(col_shader)
      fusion_shader.Message(c4d.MSG_CHANGE)
      if existing_shader:
          fusion_shader[c4d.SLA_FUSION_BASE_CHANNEL] = existing_shader
          fusion_shader.InsertShader(existing_shader)
      mat[c4d.MATERIAL_COLOR_SHADER] = fusion_shader
      mat.InsertShader(fusion_shader)
      mat.Message(c4d.MSG_CHANGE)
      mat.Update(True, True)
      The error is for th eline:
        On 07/03/2017 at 01:11, xxxxxxxx wrote:
        any GeListNode can only be part of one single list. Before insertion into a new list, you need to remove it from the old list (existing_shader.Remove()).
          On 07/03/2017 at 01:41, xxxxxxxx wrote:
          Thanks Andreas, works perfectly, I understand better now.
